Old Jun 24, 2006, 12:59 PM
pburress is offline
Find More Posts by pburress
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
How to remove shaft from BP-21
I bent the shaft on my BP-21 and need some advice.
can this be removed? and if so, how?
Also, can I replace it with a shaft from, say, a GWS EPS-350C gearbox?
Phil
pburress is offline Find More Posts by pburress
Old Jun 24, 2006, 01:24 PM
bob2005 is offline
Find More Posts by bob2005
Joined Oct 2005
Phil
Phil; Click on this ,scroll down towards the bottom of the page to
" disassemble motor" Also a replacement shaft is sold for the BP21.
http://www.bphobbies.com/view.asp?id...97&pid=U422859
Bob
bob2005 is offline Find More Posts by bob2005
Old Jun 24, 2006, 03:05 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Thanks, got it!
Old Jun 24, 2006, 03:36 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I straighten those kind of shafts all the time. If you have a drill press, it's easy. You might even try putting the shaft in a regular drill chuck. Questions?
hoppy is offline Find More Posts by hoppy
Old Jun 24, 2006, 04:04 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Good instructions there, Bob, but I do question the tool choices - I don't own an adjustable wrench, and I never will (again ). On step 3, I strongly advise that you put the motor inside a clear plastic bag first, or you will lose the e-clip for sure (ask me how I know ).
If it were my motor, I'd just grind off the bent part with a dremel/cut-off wheel, and use a wobbly prop adapter instead.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jun 24, 2006, 06:19 PM
pburress is offline
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Well, since my last post, I got the shaft out, straightened it, installed a prop adapter, flew it in my Formosa, and crashed it! I haven't checked the motor damage yet... Thanks for your help!
Old Jun 25, 2006, 01:34 AM
e-guru is offline
Find More Posts by e-guru
phillyphly
e-guru's Avatar
United States, PA, Philadelphia
Joined Sep 2005
Yes! How do you get the shaft back to true with a drill press? Spin the shaft into a steel block with a hole of the same diameter?
I've never been able to bend or hammer mine straight and have gone to wobblies to prevent bent shafts also
e-guru is offline Find More Posts by e-guru
Old Jun 25, 2006, 01:50 AM
world_hobby is offline
Find More Posts by world_hobby
Joined Aug 2005
If you do shorten the shaft, be sure to put the nut on BEFORE you grind the shaft down.
world_hobby is offline Find More Posts by world_hobby
Old Jun 29, 2006, 10:35 PM
Skully is offline
Find More Posts by Skully
Bring a shovel
Skully's Avatar
New Caney, TX
Joined Jan 2006
WH, you actually gave the guy some good advice. Yup, put the nut on first. After you cut the shaft, then remove the nut and it will help straighten the threads.
Skully is offline Find More Posts by Skully
Old Jun 30, 2006, 07:18 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Place the shaft in the chuck up to the bend.
Put an object on the drill press bed that is parallel to the shaft/drill chuck. This will be your test guage.
Turn the chuck by hand and compare the angle of the shaft to the object. You can easily see if it's straight or not and which way it is crooked.
Tap lightly on the crooked side and compare it with the test guage. Continue to do this till the shaft is parallel with the test guage.
Finally, turn the drill press on and see if any wiggle remains. If it's too much, go back to step 1.
Old Jun 30, 2006, 09:25 AM
e-guru is offline
phillyphly
e-guru's Avatar
Joined Sep 2005
Thanks, hoppy!
I see that the drill is visual aid and not an "automatic shaft straightening jig"
Good idea nonetheless!
Discussion How do i remove the Shaft from the Main gear on Blade CP? JStory Micro Helis 7 Apr 20, 2006 09:19 PM
How to remove paper from foamboard - HELP !! Flyfan Parkflyers 27 Jun 28, 2002 07:24 PM
Monokote Glue,How to remove glue from top covering? speedo Electric Plane Talk 4 Apr 11, 2002 08:27 AM
how to remove econocote from my twinstar flyer10 Foamies (Kits) 1 Apr 21, 2001 12:54 AM
