Old Jan 20, 2005, 06:38 PM
rayruby is offline
Find More Posts by rayruby
Joined Jan 2005
Xrb
i have removed the servo arms and one of the servos is turning all the time is this normal, any help would be gratefull
Ray :
rayruby is offline Find More Posts by rayruby
Old Jan 20, 2005, 08:11 PM
rickyblaze is offline
Find More Posts by rickyblaze
Professional Tinkerer
rickyblaze's Avatar
Bloomington Monroe Cty, Indiana, United States
Joined Jul 2003
That is not normal. maybe the position pot is broke or bad ,not real sure. I do know one thing that you can't buy just that part.
rickyblaze is offline Find More Posts by rickyblaze
Old Jan 21, 2005, 04:55 AM
coaxial-gyro is offline
Find More Posts by coaxial-gyro
coaxial-gyro's Avatar
uk
You'll need to recentre the transmitter trims , see if that'll centre the servo. I would sugest the servo is ' hunting ', for the center point .
I'll have to agree with rickyblaze.
If you.ve gotten the servo dirty ! ( dropped in a pond !? ) then treat it with a bit of spray lube/Switch-cleaner.
coaxial-gyro is offline Find More Posts by coaxial-gyro
Old Jan 21, 2005, 11:49 AM
rayruby is offline
Joined Jan 2005
The xrb has not been wet i was flying as normal on my second flight it would not get of the ground, it kept wanting to roll to the left on take of i held the xrb and noticed the lower blades under full throttle leaning to one side then i noticed the swash plate of centered the servo on the left side was not working when i removed servo arm it just turns without stopping, beging to thinck its faulty i will try and re center tonight
thanks Ray
Old Jan 21, 2005, 01:59 PM
Aerospacer is offline
Find More Posts by Aerospacer
Aerospacer's Avatar
United States, MN, Big Lake
Joined Sep 2003
Servo rotating 360:
Most servos have mechanical stops in their gear train that prevent them from driving more than about 270 degrees. I have had one of the Lama servos apart and they have a unique planetary reduction drive that I don't think they will stop rotating unless the servo motor current is stopped by the electronic position circuitry. The position feedback pot sits on top of the servo output shaft. I found that the pot case had snapped open on mine which could prevent the pot's wiper arm from contacting the resistance ring. Otherwise you may have a failure in the onboard position circuit for that servo. I don't think anything in the controller could cause this kind of a problem.
Aerospacer is offline Find More Posts by Aerospacer
Old Jan 21, 2005, 02:59 PM
OlatheFlyer is offline
Find More Posts by OlatheFlyer
OlatheFlyer's Avatar
United States, KS, Wichita
Joined Dec 2004
Sounds like a warranty issue to me.
OlatheFlyer is offline Find More Posts by OlatheFlyer
Old Jan 21, 2005, 03:10 PM
rayruby is offline
Joined Jan 2005
well guys i found the problem one of the three servo wires had come away from the solder reattached it now working fine
thanks for all your help
Ray
