Old Oct 14, 2015, 08:49 PM
SKT is offline
SKT
Find More Posts by SKT
SKT
SKT's Avatar
Australia, QLD, Brisbane
Joined Jul 2011
Eagle Eyes - Where does it get its centre pan bearing from?
I have my Eagle Eyes running great but I am curious about the centre pan bearing it gets itself.??
If you walk your model out 20-30m and tell the EE the model is pan centre then lookingh at the EE via the Vector OSd it gets a bearing whihc is always accuratecompared to a compass.
My question is does the EE have an onboard compass or is this some sort of back bearing from the Vector'd model?
Its not a fault.. I'm just curious where it gets that bearing from.
I've been setting it up and assigning the bearing based off my compass and its worked fine.
SKT is offline Find More Posts by SKT
Old Oct 15, 2015, 08:29 AM
JohnET is offline
Find More Posts by JohnET
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Hello,
There are 2 options. You can use the model position for the center pan or you can use north for center pan.
Per the Eagle Eyes manual;
Use Model Location as 0 Pan – This option let’s you set the Zero Pan Compass reading described above, by positioning your model in front of your tracker, as far away as possible, with your tracker’s pan servo centered. To use this option you must first ensure that the Vector has established its “home” GPS location. Then, move the model as far away from the antenna as practical, ensuring that the model is lined up with the patch antenna on the pan/tilt mount, and that the tracker’s pan servo is centered. Then, select this option, and the Zero Pan compass angle reading is automatically computed.
c) Use Present Compass as 0 Pan – if you have enabled and calibrated the Vector’s magnetic compass, this menu item will use the model’s present compass reading as your tracker’s the 0 pan direction. Point your model so that the arrow on the GPS/MAG’s label is pointing in the same direction your tracker is pointing when it is centered, and select this menu item.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Oct 15, 2015, 11:19 AM
Willyspu is offline
Find More Posts by Willyspu
United States, CA, Woodside
Joined Mar 2013
Here is a new video that really helps to set up the EE tracking station:
Eagle Tree Antenna Tracker Tutorial - RCGroups FPV Video Review (9 min 57 sec)
Willyspu is offline Find More Posts by Willyspu
Old Oct 15, 2015, 04:05 PM
SKT is offline
SKT
SKT
SKT's Avatar
Joined Jul 2011
Originally Posted by JohnET View Post
Hello,
Use Model Location as 0 Pan Ė This option letís you set the Zero Pan Compass reading described above, by positioning your model in front of your tracker, as far away as possible, with your trackerís pan servo centered. To use this option you must first ensure that the Vector has established its ďhomeĒ GPS location. Then, move the model as far away from the antenna as practical, ensuring that the model is lined up with the patch antenna on the pan/tilt mount, and that the trackerís pan servo is centered. Then, select this option, and the Zero Pan compass angle reading is automatically computed.
c) Use Present Compass as 0 Pan Ė if you have enabled and calibrated the Vectorís magnetic compass, this menu item will use the modelís present compass reading as your trackerís the 0 pan direction. Point your model so that the arrow on the GPS/MAGís label is pointing in the same direction your tracker is pointing when it is centered, and select this menu item.
Regards, John
Thx John that certainly does clear it up.
I must say that Eagle Tree has truely ticked a bunch of boxes with the Vector and the integration with the Eagle Eyes. Thank you.
Discussion So where does one get Hitec Dual Con rx crystals from in Australia? Roachie Australia 15 Oct 24, 2014 10:28 PM
Sold Eagle Tree (Eagle Eyes) (Antenna Pan/Tilt for Eagle Eyes) flyingskyhigh FPV Equipment (FS/W) 1 Oct 14, 2014 11:12 PM
Discussion where does this receiver get power from? Florin Andrei Beginner Training Area (Aircraft-Electric) 4 Dec 31, 2013 06:15 AM
Sold Eagle Eyes Pan & Tilt Antenna tracker from ElectronicaRC.com Mikey636 FPV Equipment (FS/W) 12 Nov 06, 2012 08:16 AM
Discussion What does 8 and 10 beeps mean from the eagle eyes? kilwein Eagle Tree Systems 7 Jan 29, 2011 12:08 PM
