Old Dec 09, 2014, 05:34 AM
Dr. Vork is offline
Find More Posts by Dr. Vork
Netherlands, GE, Nijmegen
Joined Sep 2014
Motors pointed inwards on multi engine plane?
Hi,
I'm building a small ( 30") 2 engined model (Aztec two step, from Outerzone). The Original model has 2 .020 cox motors on it. I want to equip it with 2 turnigy park250 electric motors in a counterrotating setup. The plan says that the motors should be pointed inward. I have seen more Multi engined plans with the motors (thrust) pointed inward.
My questions are:
Why are the motors pointed inwards?
Do I need to point the motors inward with the counterrotating setup?
If yes, how many degrees?
Thanks in advance.
Dr. Vork is offline Find More Posts by Dr. Vork
Old Dec 09, 2014, 06:54 AM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
i have heard just the opposite. someone in the know will chime in.
walter3rd is offline Find More Posts by walter3rd
Old Dec 09, 2014, 07:52 AM
pmisuinas is offline
Find More Posts by pmisuinas
United States, VA, Springfield
Joined Feb 2000
I have never seen twins or multi-engine models with motors pointing inwards--it is always out. This is a holdover from fuel engines, because if one engine quits, the outthrust will help overcome the drag of the dead engine, and hopefully help with controllability.
An engine out is not a great concern with electrics, especially if you are using one battery for both motors. in the case of a counter-rotating setup, I put both motors with no side thrust--just pointing straight ahead. However, based on the model design, you still might need down thrust or up thrust...Pete M
pmisuinas is offline Find More Posts by pmisuinas
Old Dec 09, 2014, 08:40 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Agree. Especially with counter rotating engines (you want the prop to descent toward the fuselage and rise toward the wing tip on a counter rotating setup). So no side thrust at all. Down thrust per original plans but you are also probably turning a larger scale size prop with electric too so ensure you have clearance at the stock wing mount locations so you choose the right kv motor and prop combo.
Eddie P is offline Find More Posts by Eddie P
Old Dec 15, 2014, 10:12 AM
DaveA is offline
Find More Posts by DaveA
Lawrence, Kansas
Joined Dec 2001
Can't think of any good reason for motors pointing in. A couple "semiscale" DC-3 kits had motors noticeably angled out, which my buddy who flew DC-3s found quite amusing. Angling motors toward each other just wastes thrust, makes no sense to me. I suppose it might have something to do with both props turning the same direction, but as others have said, it would increase problems in an engine-out situation.
I believe that glow engines can't be reversed (can only turn in one direction), whereas it is easy to reverse electric motors. So, assuming you can get matching right- and left-hand props, motors should be straight, not angled, because each motor will cancel the torque and P-factor of the other, and there is no "critical engine" as there is when both props turn the same direction.
DaveA is offline Find More Posts by DaveA
Old Dec 15, 2014, 10:35 AM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
Not sure if the motors originally did, but the Cox .020 motors are capable of running either
direction. Reed intake valves don't know direction.
I have several electric twins and all of them have the motors angled out. They are all CR.
BHOFM is offline Find More Posts by BHOFM
Discussion Popular Twin-Engine & Multi-Engine Prop Planes ? JD-Slow-Thumbs Electric Plane Talk 35 Aug 01, 2014 01:00 AM
Discussion High gain antenna on the PLANE with a tracker pointing to the ground station szangvil FPV Talk 13 Nov 26, 2013 03:35 PM
Discussion Wiring motors and controllers on multi-motor giant planes larryross Giant Electric Planes 12 Feb 22, 2012 11:09 AM
Question Info on Multi-Engine Plane FlyingW Toledo Weak Signals RC Expo 4 May 27, 2009 11:28 AM
