Old Sep 13, 2014, 03:44 AM
Sarboy is offline
Find More Posts by Sarboy
Sarboy's Avatar
Joined Mar 2010
Back up power in case of BEC burn out.
Hi all,
Last year I built a 1m pylon racer type plane and had lots of fun. However, due to poor cooling, the motor overheated and caused the ESC to burn out, with lots of pretty smoke.
This also led to the plane crashing as the BEC went up with the ESC and the RX then had no power.
I remember someone at the time saying one could use a small 1s pluged into a spare RX Chanel to provide emergency power to keep the RX and servos functioning to get you back to the ground instead of a lockout! They also said that as its only 1s it would receive a trickle charge from the BEC while the main batt was plugged in and so be ready to go as and when needed.
So, my question is, will the above work assuming the RX is capable of working at such low power levels? It seems a nice and above all LITE way of a bit of safety.
Chees
Tom
Sarboy is offline Find More Posts by Sarboy
Old Sep 13, 2014, 06:09 AM
steveburns is offline
Find More Posts by steveburns
steveburns's Avatar
Chipping Norton, UK
Joined Jan 2005
That would most likely set the 1s Lipo on fire as it be getting charged to whatever voltage the BEC was running at(5 to 6 volts). It might even make the ESC go pop as the current going to the Lipo could be more than the BEC can deal with.
The only real safe way of doing it is to run a separate RX supply and remove the red wire from the ESC or fit a opto between the ESC and RX.
Assuming you're not running massive power on a model like that why not just give things the required amount of cooling and run as normal? My Wot 4 with 1kW and 5 servos has been running BEC for years now.
Steve
steveburns is offline Find More Posts by steveburns
Old Sep 13, 2014, 04:57 PM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Cheers Steve.
I'm not worried about the cooling of the motor. My last one failed because I didn't give it fresh air and its a mistake I won't be making again. But, that's not the only reason a BEC could fail and it's a shame to lose an airframe due to the RX and servos having no power.
I am just trying to find a way of a light weight battery back up. It seemed a reasonable way of achieving the aim with out a full blown dedicated RX batt.
These models are at there best if kept light and they are always at a premium for space.
Maybe another idea will materialise.
Old Sep 13, 2014, 06:15 PM
jsnaphook is offline
Find More Posts by jsnaphook
Why you swing so hard?
jsnaphook's Avatar
Lake Tahoe
Joined Jun 2006
How about an external BEC?
Juan
jsnaphook is offline Find More Posts by jsnaphook
Old Sep 14, 2014, 01:51 PM
areid is online now
Find More Posts by areid
Auckland New Zealand
Joined Aug 2007
Look into the scorpion backup guard
areid is online now Find More Posts by areid
Old Mar 02, 2015, 11:10 PM
johnorama is offline
Find More Posts by johnorama
UAV Dude KF7HYV
johnorama's Avatar
United States, NV, Silver Springs
Joined Mar 2007
This circuit would also work. It is made in the U.S.A.
http://lasercuttingbyjohn.com/produc...p-bec-circuit/
johnorama is offline Find More Posts by johnorama
Site Sponsor
For Sale Modeltech P-47 Razor back ARF pick up Plymouth, IN $125 Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 6 Jun 13, 2014 03:57 PM
Sold Back up forsale...never received payment....E-Flite 60Aesc/ switched bec and E32 moto crosby Aircraft - Electric - Power Systems (FS/W) 2 Apr 26, 2014 08:41 PM
For Sale Complete power set up for 25% (30cc) plane (Tacon motor, HV esc, CC 20A BEC Pro) badkarma Aircraft - Electric - Power Systems (FS/W) 3 Dec 23, 2013 02:19 PM
Discussion Back-up Rx battery to main power BEC. ronhowell Power Systems 7 Jul 28, 2012 03:13 AM
Discussion Can a short in a servo line burn up a BEC? astroboy Power Systems 10 Sep 06, 2011 12:31 PM
