Old Dec 03, 2014, 04:46 PM
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
JW elevons
Hey,
I'd like to fix a portion of the outer elevon to the wing. Can someone give me the approximate angle of the "reflex" in trimmed position? I'm thinking flat with the bottom surface of the wing, but just want a sanity check before I glue them.
Cheers
Red
Alien_Tech is online now Find More Posts by Alien_Tech
Old Dec 03, 2014, 06:55 PM
Get your build on!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
If you already flew and trimmed the plane, match that angle. Otherwise follow the bottom curve of the airfoil.
Another option is to tape the fixed portion on and test fly the plane, then adjust the fixed portion to the as-trimmed elevon position.
Aerogance is offline Find More Posts by Aerogance
Old Dec 03, 2014, 07:08 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Thanks. Not flown yet as I'm still building.
Cheers
Red
Old Dec 04, 2014, 02:37 PM
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Following the bottom of the foil will get you close.
Mine are rarely perfect but will still go 200+.
1000MPH is offline Find More Posts by 1000MPH
Old Dec 04, 2014, 04:04 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Great, that's what I did.
Red
Old Dec 05, 2014, 12:44 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Fuse and fin done, gooping the wing now, maybe covering by tonight,
Old Dec 05, 2014, 02:15 PM
Get your build on!
Aerogance's Avatar
Joined Sep 2008
Go go go! You build faster than me!
Old Dec 09, 2014, 12:03 AM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Made some progress over the weekend. Need to find some black striping tape before I finish it up. Elevons going on soon so I can check balance. Hopefully it will blow enough this weekend for a maiden.
Red
Old Dec 09, 2014, 09:11 AM
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Cool design. What's up with the kink in the fuselage?
Old Dec 09, 2014, 10:00 AM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
When I put the carbon rods in the fuse it deformed it slightly. It pushes down easily and will go away when it gets glued on.
Old Dec 10, 2014, 12:27 AM
Get your build on!
Aerogance's Avatar
Joined Sep 2008
Looks fantastic Red! What did you do for the colors on the bottom of the wing?
Old Dec 10, 2014, 08:44 AM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Nothing on the bottom yet, but it will likely get some sort of orange striping in a different pattern.
Red
Old Dec 14, 2014, 08:22 PM
Get your build on!
Aerogance's Avatar
Joined Sep 2008
Updates? Should be done by now based on the pace you have!
Old Dec 14, 2014, 09:51 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Nearly done, I finished up the linkage today. I'm just waiting on some better hinge tape & CG.
Red
Old Dec 14, 2014, 10:06 PM
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Bring it up to Weldon next weekend.
I like the Gulf Racing scheme.
Looks like you're going to have clearance issues with the linkages.
Discussion JW 36 (The Mini JW) Aerogance Dynamic Soaring 22 Yesterday 06:23 AM
Discussion Airtronics Stylus programming for JW elevons KurtMc Dynamic Soaring 4 May 25, 2008 04:49 AM
Discussion JW elevon width shoe Slope 3 Apr 21, 2007 12:23 AM
Discussion one day fix of an JW elevon Fly'n fish Slope 4 Dec 24, 2006 01:54 PM
Discussion Can't find answer. Jr R770s Rx going in a JW, Elevon channel help! KingOfTheHill Slope 11 Mar 06, 2006 09:46 PM
