Old Oct 30, 2014, 08:18 AM
Canada, ON, Palmerston
Joined Sep 2014
video tx/rx question
hey everyone just wondering what the best video tx/rx for long range would go good with the dragonlink v2 setup.
flycrazy1981 is offline Find More Posts by flycrazy1981
Old Oct 30, 2014, 09:31 AM
The Fixer
Canada, ON, Mississauga
Joined Jan 2009
Depends on how far you wanting to go. From where you are 200mw will get you a good distance. And most will work with a dragon v2 system.
Martin Y is offline Find More Posts by Martin Y
Latest blog entry: Flyfly Fox Glider
Old Oct 30, 2014, 02:08 PM
Joined Sep 2014
what u mean likr the dragon link is for plane and if it says 40 km then i want video at least half that so i have no worrys ever for eather
Old Oct 30, 2014, 02:49 PM
The Fixer
Joined Jan 2009
Since you are new to fpv. Start out very short distance for a bunch of flights, less than 1 km then progress farther out as you feel comfortable.
Old Oct 30, 2014, 09:09 PM
Joined Sep 2014
well thats what i been doing all summer i want to start going out more now that why i am upgrading thats why i want the peoples vote on video tx/rx
Old Oct 30, 2014, 11:56 PM
yzguy's Avatar
Florida
Joined Mar 2007
I took my small wing out 5 miles! (new distance record for me but only came back 4 miles , different story, but I found it, very little damage )
Also showing how far you can go with 200 mw tx, and a directional antenna.
4.9 miles
854 feet high
61% rssi
Flying from inside my house, small DL antenna, low power
200 mw 1.2 vid TX
1.2 TX antenna:
on channel 1 of diversity
4 channel 1.2 vid RX
Yagi RX antenna
on channel 2 of diversity
900-1.3 RX
BiQuad 11dbi antenna I made
I was testing to see which rx antenna worked better, but so far they seem pretty close.
I may still swap receivers and repeat to see if that makes a difference.
yzguy is offline Find More Posts by yzguy
Latest blog entry: wing wing z-84 fpv setup
Old Oct 31, 2014, 07:12 AM
Joined Sep 2014
see right now i am using the skyzone goggles v2 and a boscam 600mw tx with the fy 41ap lite
and mobious cam all in the sky surfer and i have mushroom on plane and goggles with sprial on goggles to but i am ucky to get 500 meters away be4 losing video this setup to is all 5.8ghz this is why i am asking
Old Nov 02, 2014, 12:03 AM
yzguy's Avatar
Florida
Joined Mar 2007
that does not sound very good.
I had a fat shark clover leaf V1 on a 200 mw 5.8 tx
and a V1 skew planar wheel on the RX
V2 is here:
https://www.hobbyking.com/hobbyking/...a_V2_SMA_.html
with this setup I got 1.75 miles
I will say though, that I tried a couple of different RX's though, 2 with the diversity built in, and many did not get that range. It is like they are a slightly different frequency, and actually pick up the TX on 2 different channels (they are the ones with a lot of channels) bu that the RIGHT channel is in between those 2.
Discussion Question on Immersion 600mW video TX Made in Austria FPV Equipment 2 Oct 06, 2014 10:45 PM
Sold getfpv 2.4ghz 1w video rx tx blue beam cp antenna quad pilot 07 Aircraft - Electric - Multirotor (FS/W) 2 Sep 21, 2014 08:01 PM
For Sale getfpv 2.4ghz 1w video rx tx blue beam cp antenna quad pilot 07 FPV Equipment (FS/W) 0 Sep 21, 2014 02:52 PM
Question quick video tx rx question mholzschuh FPV Talk 3 Feb 23, 2014 11:24 PM
Sold Video Tx+video Rx+video monitor(with 2nd integrated vid Rx)+patch ant+more $50 shippe john-doe FPV Equipment (FS/W) 5 Jan 15, 2014 09:45 AM
