Old Mar 01, 2012, 09:33 PM
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
What about ESCs? Hobbyking red brick 40A or 50A a good match?
sammyc is offline Find More Posts by sammyc
Old Mar 02, 2012, 01:38 AM
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
I was using a 40A on mine before swapping it out for a 1400kv (in my EZ) - still use the 40
Edit:
I've been looking all morning for the source of those 'squash bottle plastic' belly protectors.
Can any kind soul point me to the vendor again please? (they were about $15 each I think)
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Mar 02, 2012, 08:21 AM
Bill
HiFlyer371's Avatar
United States, NE, La Vista
Joined Jul 2007
My 2826-6-2200KV draws 26 Amps at WOT and I'm using a 35 Amp (40 burst) ESC. Figure on an ESC that is rated for 15 to 20% more then you'll need.
HiFlyer371 is offline Find More Posts by HiFlyer371
Old Mar 02, 2012, 09:02 AM
United States, WI, Fond du Lac
Joined Sep 2008
Here's how I did my Bixler motor mount. Scanning this thread, I haven't seen it done exactly this way so I thought I would post it.
I took the stock wood block, glued a 1/8" ply disk to it, and added 4 bamboo skewer "bolts" to tie the whole thing together. I sanded a flat on the end of the motor pod to match and glued the whole unit in with white GG. Before I glued it in I opened up the wiring chase a bit and took out most of what seemed excessive side thrust.
Pictured are two motors I thinking about. RC-timer CF2812 1535 KV (7" prop) or a Suppo 2212-6 (6" prop). I've run both on a Polaris.
pmullen503 is offline Find More Posts by pmullen503
Old Mar 02, 2012, 10:39 AM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Very good. Someone makes a laser cut one that's similar but I will be darned if I can find it.
Prof100 is online now Find More Posts by Prof100
Old Mar 02, 2012, 10:48 AM
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Cool ESC cooling
Lower temp = less amps = more flight time
greedyg76 is online now Find More Posts by greedyg76
Old Mar 02, 2012, 10:51 AM
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Are you guys mounting the Turnigy 2826 to the stock plastic mount?
I noticed the 2826's came back into stock.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Mar 02, 2012, 11:37 AM
Bill
HiFlyer371's Avatar
Joined Jul 2007
ReadMadeRC.com
http://www.readymaderc.com/store/ind...products_id=13
Old Mar 02, 2012, 11:54 AM
Suomi, Uusimaa, Pusula
Joined Jan 2012
The Brixler
Description:
Here is a pic of my "Brixler" Isn't she a beauty?
underside wingtips are painted black
I bought the rtf version which I now, after 2 months in rc regret. Should have bought the kit version.
Mods / replacements:
30A hobbyking blueseries esc
APC 6x4EP prop
All servos replaced with HXT900 servos
4mm CF rod under fuselage (this was mistake, should have used 2.5 or 3mm)
3m dual lock to hold wings together
Dubro pushrod guide added to support rudder pushrod
replaced stock control horns with Kawan micro horns
stock wing spar reinforced with solid cf rod
Replaced stock aileron pushrod/clevis with dubro pushrods & nylon clevis
Packing tape reinforced belly / hinges / underside of wings
Turnigy nano-tech 2200mah 3s lipo
Next step is the flaps and maybe add some cf rods to wings and tail, then she's pretty much done.
So whats left is the stock 6ch receiver and motor.
AHell is offline Find More Posts by AHell
Old Mar 02, 2012, 01:08 PM
United Kingdom, England, Ripon
Joined Dec 2011
For anyone who says you cant have fun with a "Powered Glider"!!!!
Thrashing the Bixler (3 min 33 sec)
Simon2504 is offline Find More Posts by Simon2504
Old Mar 02, 2012, 04:45 PM
Bill
HiFlyer371's Avatar
Joined Jul 2007
Look 2 post up from your original post.
Old Mar 02, 2012, 06:27 PM
RVA
RVA's Avatar
United States, CA, Long Beach
Joined Jan 2011
BH - new 800mm Skysurfer-esque glider???
Yes, technically off topic but definitely relevant. Looks like it has potential. Currently advertised as RTF. Hope it comes in a ARF at some point - might be worth a shot. Obviously part of BH's new FMS offerings. Does anyone know if this exact FMS model is being offered by anyone else?
http://www.bananahobby.com/2297.html
RVA is offline Find More Posts by RVA
Old Mar 02, 2012, 06:45 PM
sammyc's Avatar
Joined Nov 2011
I think hobbyking has a few similar planes? Dunno if its the same one though
Old Mar 03, 2012, 01:06 AM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Sunset FPV - March 2nd, 2012 (11 min 45 sec)
My sunset bixler flight today
NorCalMatCat is online now Find More Posts by NorCalMatCat
Old Mar 03, 2012, 01:27 AM
'scuse me while I kiss the sky
Lafayette's Avatar
Joined Nov 2009
Originally Posted by HiFlyer371 View Post
Right on HiFlyer support our troops!
Lafayette is offline Find More Posts by Lafayette
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
