Old Mar 07, 2013, 02:48 PM
joaomoro is offline
Find More Posts by joaomoro
Joined Mar 2013
Help!
Help-turnigy 9xr
hello anyone could help me, how do I configure heli 450 in Turnigy 9xR with original firmware?
thanks
joaomoro is offline Find More Posts by joaomoro
Old Mar 07, 2013, 03:18 PM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
Help
thanks
Go to the Turnigy 9XR thread. There have been lots of requests and answers for heli setups and where to find tutorials. You may have to go through lots of pages to find the specific posts, but they are there if you look through them.
Also, you may want to try YouTube, as some of the How to Vids are there as well.
jchtr3a is offline Find More Posts by jchtr3a
Old Mar 07, 2013, 11:26 PM
old4570 is offline
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Hmmm , I only just got mine set up .. Still need to work out DR and expo ..
But where are you stuck ?
old4570 is offline Find More Posts by old4570
Old Mar 07, 2013, 11:28 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
Here ya go. Helped me tons when I first my heli up.
How Set Up TH9x for CCPM 450 500 600 Helicopter (25 min 9 sec)
ASTREA1 is offline Find More Posts by ASTREA1
Old Mar 09, 2013, 10:26 AM
joaomoro is offline
Joined Mar 2013
Hello happens that the system of new Turnigy 9XR are quite different, I do not know how to set up the heli 450
Old Mar 10, 2013, 04:17 AM
old4570 is offline
Australia, VIC
Joined Dec 2011
Ok
I can get you to where I am , .....
Make sure your Rx is bound to the Tx ...
Then sort out your servos , ele , ail , rudd , Cyclic .. ( Cyclic can wait )
Just get you servos working ... AKA for a plank ..
Now for the heli part ..
Make sure you have a model set up ( Model 01 ) or name it what ever you like .
3rd screen in menu is heli set up
Swash type is 120
Thats all you need for now ..
Go to the mixer menu ....
I have cyc1 to 3 set to 50%
Ch4 is rudder
and Ch5 is throttle
Next the reverse menu
I only have one ch reversed and thats for cyclic - Ch3
Now I dont remember going with the template ,
but in templates you can try the heli set up template ( I found no joy with it )
ATM I need to work out how to set DR and expo
Hardest part was working out the cyclic servos as Im using the orange module ..
So with the current settings my 450 hovers well , just a little trimming ( flight ) needed ..
Though I would like to work out DR and expo ...
What I dont like is where the capital F is my throttle curve and pitch curve .. Sure is something to be said for the older 9x , very nice for setting up a heli ..
Old Mar 10, 2013, 11:23 AM
joaomoro is offline
Joined Mar 2013
Swash type is 120
Ch4 is rudder
and Ch5 is throttle
it is possible to put the firmware on Turnigy 9x, on 9XR Turnigy!
my module is orange
Old Mar 10, 2013, 07:06 PM
old4570 is offline
Australia, VIC
Joined Dec 2011
Yeah
Thats what I was wondering ...
But there is different firmware one can try and flash to , I dint know why HK chose this one ..
The other firmware may be proprietary ( owned by flysky )
There are 2 or 3 9x forums .. and several versions of firmware to try ..
I havent tried flashing as yet ...
Is your Rx bound to the Tx ? if not this is the first thing to do ...
OrangeRX DSMX/DSM2 2.4Ghz Transmitter Module in Turnigy 9XR BIND (2 min 19 sec)
Old Mar 10, 2013, 11:22 PM
joaomoro is offline
Joined Mar 2013
http://www.youtube.com/watch?v=OSrOsVy8Hwk
yes is connected with my TX
Old Mar 11, 2013, 05:24 AM
old4570 is offline
Australia, VIC
Joined Dec 2011
Ok , so all thats left to do is work out where the cyclic servos go ...
On the Rx [ mine ] they went into chnl's 1,2, and 3 , throttle on mine is chnl 5 , rudder is chnl 4 so I guess chnl 6 is for the gyro signal wire... So have you got the servos plugged in ?
Also you want to set up the swash type to 120 , so that the servos will mix ..
From here its a matter of working out which servo is which and which servo needs reversing ..
Now I can tell you , on mine , Chnl 1 = Elevator .. That is the rear most servo ( cyclic )
Chnl 2 and 3 are for your two front servos , aileron and cyclic , youl have to work out which is which as I cant tell as the wires are routed inside the body ..
Let us know how you go ...
Old Mar 11, 2013, 11:03 AM
joaomoro is offline
Joined Mar 2013
its rx is the same as mine?
which would be the first channel top to bottom or bottom to top
Old Mar 11, 2013, 04:35 PM
old4570 is offline
Australia, VIC
Joined Dec 2011
615
http://www.hobbyking.com/hobbyking/s..._Receiver.html
I used the 615 Rx for this one ,
I also have the 610 http://www.hobbyking.com/hobbyking/s...Sat_Port_.html
Which Im not using ATM
Question Turnigy 9XR rickthebrewer Radios 10630 May 04, 2015 03:41 PM
Discussion Turnigy 9x vs turnigy 9xr Harry200sx Radios 2 Feb 08, 2014 04:40 AM
Discussion NEW Turnigy 9XR transmitter....Release LexusFPV Electric Plane Talk 1 Nov 13, 2012 05:50 PM
Question Turnigy 9xr Levictus HobbyKing 7 Oct 13, 2012 08:26 AM
