Old Jan 18, 2008, 05:58 AM
Joined Dec 2007
Rx for ritewing question..?
Hey,
I'm starting to put together my list of parts for my upcoming ritewing collection and have decided on the DX6i radio for cost / 2.4 advantages.. but I need a little help on the rx end, I have noticed all the video's and pictures of the ritewings in flight seem to have rx wire hanging out of the wingtip and assume this is on NON-2.4 electron 6 rx's... now I have set my sights on the AR6000 due to the low cost (44.95) but they seem to do a 6100 , 6200 etc... and i am unsure if the RANGE of the different rx's is different?? will my fast ritewing be too far away for a AR6000?? do i need to get a longer wire? the antenna on the 6000 seems to only be 30mm's long??
which one should i buy??
thanks
WSdude
wingsuitdude is offline Find More Posts by wingsuitdude
Old Jan 18, 2008, 06:07 AM
Pasco County Florida
Joined Dec 2006
The length of the antenna wire is dependent upon the frequency of the receiver. That is, the higher the frequency the shorter the antenna. Therefore a 72mhz radio needs a longer antenna than a 2.4ghz radio.
Just use the antenna that comes with whatever radio system you are using and you will be okay.
The Spektrum 6100 is intended for park flyers. The 6200 is a full range receiver. I recommend the 6200 for safety reasons.
Bob
Bayward is offline Find More Posts by Bayward
Old Jan 18, 2008, 08:12 AM
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
I have a DX7 and am currently building my TL50. I have choosen the AR6200 for the range and redundancy. I am powering the AR6200 with it's own small 3s lipo that i got from CK and a Castle 10 amp BEC. That short antenna is the proper length for 2.4 Ghz and should not be messed with.
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Jan 18, 2008, 08:55 AM
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Dont go cheap on the rx, get a 6200
Atom1025 is offline Find More Posts by Atom1025
Old Jan 18, 2008, 09:24 AM
cant leave things stock
jstoll's Avatar
United States, KY, Lexington
Joined Feb 2007
Ive been using lightflightrc dual conversion Rx for years with never ever a problem
nice folks with good stuff
take care
JAK
jstoll is offline Find More Posts by jstoll
Old Jan 18, 2008, 11:33 AM
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
I have been flying with a BR6000 for a while in my TL50. Had a scary incident while using it with a DX-6 about 5 months ago. Switched to DX-7 and haven't had any repeats. I have a BR6000 on my Ritewing FS-33 and it was flying across the field and suddenly nosed in from 20' up at 3/4 throttle or so. All that to say if you can afford the AR7000 / 9000 I think you will have more peace of mind and less chances of having any issues. Also, reboot time is a killer so with the TL50 or any other ritewing it is suggested to have a separate batt for a BEC which powers only the RX.
reefboy is online now Find More Posts by reefboy
Old Jan 18, 2008, 02:36 PM
Are ya gonna be farther than 1.7 miles away?
This thread talks about the 6100 but I am sure the 6000 is similiar, heck even if it only worked at half the distance .85 miles, it would still be farther than you would ever need.
http://www.rcgroups.com/forums/showthread.php?t=783753
Farnsrocket is offline Find More Posts by Farnsrocket
Old Jan 18, 2008, 02:50 PM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Regardless we seem to have far more problems with the ritewings due to power system interferance than park flys and the such..
Even if it is rated at 1.7 that does not mean there are not a host of other problems that arise from the lower end 2.4 systems
and the link is based o the dx7 not the dx6
PaulVi is offline Find More Posts by PaulVi
Old Jan 18, 2008, 02:52 PM
I am sure that's true, I was just throwing that out there.
Old Jan 18, 2008, 04:00 PM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Sorry for sounding like a angry parent..
It is always better to have too much info than not enough
Old Jan 18, 2008, 05:11 PM
Joined Dec 2007
cheers people, i reckon an extra 30 dollars for the 6200 will be well spent, as i dont want to crash for any other reason than pilot error... i'd cry if i'd cheapo'ed on the rx by 30 bucks and then i lost signal..... so the 6200 it is..
WSdude
Old Jan 18, 2008, 05:19 PM
Naw, you're fine!
Old Jan 18, 2008, 05:46 PM
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
While we're on the subject of receivers though... I know the general consensus is electron for 72mhz, but how about a berg 4L? Corona?
Anyone flying a ritewing on these receivers? Or does pretty much everyone stick with the electrons?
-mike
msmith is online now Find More Posts by msmith
Old Jan 18, 2008, 06:28 PM
Atom1025's Avatar
Sacramento
Joined Jun 2005
Half my fleet is berg4l the other half is electron.
I have only experience one hickup with the bergs within 2 years of use, it was just a bump to one servo.
Chris dislikes them and has seen a few losses due to them but so far I have not had issues. If the plane is the 3lb ers I run the electron for cheap insurance.
Old Jan 18, 2008, 06:53 PM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Ya im sold on the electron 6's on the RW.. I use the bergs on the smaller ones
But then again i have flown a GWS6 up to 2600 feet with no problems too
Discussion F27 Stryker question. What is the spare channel on top of the ESC/RX for? randall1959 Flying Wings 3 Sep 28, 2006 07:43 PM
Rx for T-Rex Question - JR610UL skwidd Mini Helis 8 Mar 31, 2005 11:57 PM
NEW Futaba rx for sale petn7 Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2001 09:41 PM
WTB: Hitec 555 rx for Futaba ( Slope Nut Aircraft - Electric - Airplanes (FS/W) 2 Jul 28, 2001 09:54 PM
GWS Nano Rx for outdoor use robert mardell Power Systems 3 Jul 19, 2001 11:40 PM
