Old Oct 12, 2012, 06:14 AM
jdraughn is offline
Find More Posts by jdraughn
Joined Sep 2010
DIY low voltage BLDC controller?
I have been designing simple half-bridge boards that I could combine to create a variety of different motor drivers. Two of them would let me create a brushed motor driver with reverse, 3 of them could drive a brushless motor, and 4 of them could drive a bipolar stepper motor.
I was planning on using the IR2101 driver, but then I realized that they require at least 10v, so anything under a 3s battery would not work. The IR2301 will work with 5v, which would allow me to run 2s batteries, but I don't see anything for running a single lipo (3.7v), and the IR2301 cost quite a bit more then the IR2101. Digikey has the IR2101 drivers for only 1.14 each in quantites of 10, which is a great price.
Is a p-channel mosfet for the high side about the only option I have and just driving them directly from a microcontroller? I have had poor experiences with using p-channel mosfets, they always get so hot so quick, but maybe I just haven't been spending enough money on them, buying ones with a higher RDS then I could be.
So, what I guess I am asking is, does anyone know of a driver that will drive high sided n-channel mosfets with a single lipo, or is a p and n channel combo my best bet?
jdraughn is offline Find More Posts by jdraughn
Old Oct 12, 2012, 07:09 AM
jdraughn is offline
Joined Sep 2010
I just came across this article about using a 555 timer to generate the voltage needed for the high side n-channel fet: http://www.ti.com/lit/an/slva444/slva444.pdf
In this article they use it so you can have 100% duty cycle. I am going to try and build a discrete totem pole driver so I can supply my own gate voltage. I will breadboard it and see if it looks like it will work alright. If so I won't even bother with a dedicated driver IC, I will just build my own using a PWM output from my microcontroller to run the charge pump and use totem pole drivers.
Old Oct 13, 2012, 09:05 PM
Monsoon Kim is offline
Find More Posts by Monsoon Kim
ㅋㅋㅋㅋㅋ
Joined Dec 2011
Chargepump would probably be cheaper and require minimal external components - one IC, 3/4 caps.
Monsoon Kim is offline Find More Posts by Monsoon Kim
Discussion High Kv and Low Voltage or Low Kv and High Voltage PatrickRC Power Systems 47 Jul 22, 2014 09:29 PM
Discussion BLDC Motor Current Control patriots21 Power Systems 9 Jun 17, 2012 02:53 PM
Discussion DIY BLDC ESC for step control Rufe0 DIY Electronics 21 Feb 02, 2009 03:15 AM
