Old Jul 14, 2015, 08:12 PM
skyjet is offline
Find More Posts by skyjet
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
Originally Posted by lesbaron View Post
The Hacker A60 5XS V2 motor is 420 K.V. I am not sure if it will run on 8 cell. With the 6 cell it has 2164 watts at 101 amps. 18" Xoar. Not really looking for more power. I want 8 minutes of run time at normal flying. No 3D for this plane. That's what my 3DHS planes are for. Les
Is your prop an a elictric prop and what is the pitch?
skyjet is offline Find More Posts by skyjet
Old Jul 15, 2015, 01:26 PM
lesbaron is online now
Find More Posts by lesbaron
United States, MI, Bloomfield Hills
Joined May 2007
Yes it is electric. 18X8, Les
lesbaron is online now Find More Posts by lesbaron
Old Sep 16, 2015, 02:45 PM
wjbender is online now
Find More Posts by wjbender
Learnin mo ever day
United States, NJ, Tinton Falls
Joined Jul 2007
Originally Posted by skyjet View Post
Welcome to the Rascal Family! The first shipment for Rascal 110's with flaps was in December 2011. This is a great thread for the 110. I fly mine on 12 cells which has ridiculous power. Most I've seen fly on 10 cells and I know of one the flies on 8 cells. If your motor and esc can handle 8 or 10 cells you might consider that option. The 10 cell option would probably require a high voltage (HV) esc. My 12 cell Rascal only pulls 65A.
Hi Skyjet,
Thanks for all the great information on the rascal. I fly exclusively electric and lately the Rascal 110 has caught my attention. I plan to start putting one together soon. With your 12s 5000 setup what flight time are you getting?
wjbender is online now Find More Posts by wjbender
Old Sep 16, 2015, 03:03 PM
skyjet is offline
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
Originally Posted by wjbender View Post
Hi Skyjet,
I have my timer set for 7 minutes for mixed flying. I'm sure 10 minutes for light flying would be fine. 7 minutes is conservative. I still have 30% left after the flight. The latest arfs can be set up without the conversion, but I have not seen one yet.
Old Sep 16, 2015, 06:58 PM
Cabledawg1 is online now
Find More Posts by Cabledawg1
Cabledawg1's Avatar
USA, VA, Newport News
Joined Jan 2010
I also fly on 12S 5000's. I am getting 3500 watts and can hover easily. I have my timer set for 11 minutes.
Cabledawg1 is online now Find More Posts by Cabledawg1
Old Sep 28, 2015, 01:56 PM
Learnin mo ever day
Joined Jul 2007
11 minutes is very good. I'd probably be tire by then anyway.
I see from the manual that SIG recommends putting the batteries in through the windows, but I do like the conversion that Skyjet did. I may go that way - have to get my kit to see what looks best.
I'm selling some glow and electric motors now to scrape up the $$ to buy my kit
Old Sep 29, 2015, 08:56 PM
Learnin mo ever day
Joined Jul 2007
motor for SIG Rascal 110
Here is the motor I plan to use on my SIG Rascal. I plan to run on 12S as I have lots of 6S 5000 packs. I just nee to work out the prop
Scorpion SII-5525-195 Motor Specifications
Stator Diameter 55.0 mm (2.165 in)
Stator Thickness 25.0 mm (0.984 in)
Number of Stator Slots 12
Number of Magnet Poles 14
Motor Wind 20 Turn Delta
Motor Wire 18-Strand 0.33mm
Motor Kv Value 195 RPM per Volt
No Load Current (Io) 0.88 Amps @ 10 Volts
Motor Resistance (Rm) per Phase 0.034 Ohms
Motor Resistance (Rm) Phase to Phase 0.023 Ohms
Maximum Continuous Current 80 Amps
Max Continuous Power (8-cell Li-Po) 2350 Watts
Max Continuous Power (10-cell Li-Po) 2950 Watts
Max Continuous Power (12-cell Li-Po) 3350 Watts
Motor Weight 708 grams (24.97 oz.)
Outside Diameter 66.4 mm (2.614 in.)
Shaft Diameter 8.00 mm (0.315 in.)
Motor Body Length 59.8 mm (2.354 in.)
Overall Shaft Length 106 mm (4.173 in.)
Old Sep 29, 2015, 09:45 PM
Learnin mo ever day
Joined Jul 2007
Looks good with an APC 19 x 10E on 12s Calculated 2839 watts. Motor is good for 3300 on 12s.
almost 2:1 thrust to weight and level speed of 65 mph.
Old Oct 15, 2015, 11:41 AM
Learnin mo ever day
Joined Jul 2007
Can anyone tell me how many flights can I get out of a 3000 mAh LiPo flight pack if I am using digital servos?
Old Oct 15, 2015, 02:26 PM
Cabledawg1's Avatar
Joined Jan 2010
Way more flights that you could do in a day. I run 2 1100mah packs and have never come close to running them down. I imagine a 3000mah pack would give you 10 flights.
Old Oct 18, 2015, 03:16 PM
Joined May 2007
I have a new wing set for the 110 Rascal in Red. These do not have flaps. $125.00 fob Michigan if anyone need them. Les
Old Oct 23, 2015, 11:18 AM
Learnin mo ever day
Joined Jul 2007
Can anyone tell me what is a max prop size for flying off grass? 18" seems to be a popular size. I have a motor that would run well with an 18 - 19" i am building for about 3300 to 3500 Watts
Old Oct 23, 2015, 11:21 AM
skyjet is offline
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
My motor is 200kv and I run a 20 X 10E and get 3200 watts.
Old Oct 23, 2015, 06:29 PM
Cabledawg1's Avatar
Joined Jan 2010
I have a 22 x12 prop. I know for a fact that a 24 fits too.
Old Oct 24, 2015, 03:42 AM
Gerben is offline
Find More Posts by Gerben
Joined Dec 2004
Im running a 25" prop which works well on grass (some larger wheels fitted though).
Gerben is offline Find More Posts by Gerben
For Sale Sig Rascal 110 g wheeler Aircraft - Fuel - Airplanes (FS/W) 1 May 29, 2012 04:05 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Electric - Airplanes (FS/W) 3 Sep 18, 2011 09:49 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Electric - Power Systems (FS/W) 3 Sep 05, 2011 09:55 PM
Sold Sig rascal 110 red/white lpu yates55 Aircraft - Fuel - Airplanes (FS/W) 10 Apr 15, 2011 07:06 PM
Sold Sig rascal 110 red/white lpu yates55 Aircraft - Electric - Airplanes (FS/W) 14 Apr 15, 2011 07:05 PM
