Old Aug 02, 2008, 08:35 PM
jonnyjetprop's Avatar
USA, FL, Apopka
Joined Sep 2003
Wicked EDF 4000Kv and a Wattage PF
Don,
Any experience on using the 4000Kv motor on a wattage powerfan. I'm looking to hop up a S-3 Viking.
John
jonnyjetprop is offline Find More Posts by jonnyjetprop
Old Aug 03, 2008, 05:18 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have only tested in the SF fan which is basically a clone of the Wattage fan.
3S lipo with SF fan (3 blades): 37,500 rpm, 23 amps, 250 watts
I think I have a 6 blade wattage rotor I can test and get you some numbers.
Don
The Don is offline Find More Posts by The Don
Old Aug 24, 2008, 01:13 PM
USA, FL, Apopka
Joined Sep 2003
Sorry I had missed your response. Thanks for taking the time.
John
Old Sep 11, 2008, 08:39 AM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Don
I would be really curious as to the amp draw with 6 blades.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 11, 2008, 05:12 PM
USA, FL, Apopka
Joined Sep 2003
Please confirm before I order. For the Wattage Power Fan, I need the 2.3 mm shaft, motor only.
John
Old Sep 11, 2008, 05:32 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
3S lipo?
Don
Old Sep 11, 2008, 05:48 PM
USA, FL, Apopka
Joined Sep 2003
3s and I'm looking at the 4000kv for a twin S-3 Viking. I was looking at shaft size and if I need the adaptor. It looks on some photos that you used the adaptor on the powerfan, but you were using a 4800kv motor.
John
Old Sep 11, 2008, 06:02 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
On 3S you can order them with the 2.3mm shafts.
Old Jul 16, 2011, 09:38 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
i know this is old, but thats why we have a search option.
Im currently building a scratch job and im planning on using a wattage power fan 400/6 left over from a gaui i never used.
I want to go 3 blades and the kv for 4s application.
I see the options to purchase the motor with 2.3mm shaft alone, but i need the stand off and i dont see the option for 2.3mm shaft/ with standoff.
4S lipo with Eflite/SF fan (3 blades)49,500rpm, 34 amps, 450 watts Great for Efite F-15, or Gaui TigerShark, or Gaui Tigershark Delta. Standoff adapter required.
Your suggestions Don.
D_FAST is offline Find More Posts by D_FAST
Old Jul 16, 2011, 11:20 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
You want the motor with the standoff adapter and "XF rotor plug" option. That will fit the power fan rotor and mate to the 3mm shaft. You will not be using the 2.3mm rotor adapter you already have.
Don
Old Jul 16, 2011, 12:09 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
EDIT:: Gotta ya.
Ready to fire off the checkout, but the webpage for the 40amp pentiums, says due April 25th, shows 9 in stock. is this correct?
Old Jul 16, 2011, 01:53 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
They are in stock forgot to fix the webpage description.
Don
Old Aug 13, 2011, 09:41 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
bump, yea ther don? its getting close to the maiden.
Old Aug 13, 2011, 04:49 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sorry missed this one somehow. That is fine wattage, that is a little less about what it runs in the 64mm fans I sell. The high C rate pack is what is doing it. Is that reading after 15-2- seconds of run time? or only after a few seconds?
Wattage PF-12 + Car batteries? tomcor Batteries and Chargers 1 Dec 31, 2002 03:04 AM
Wattage PF-12: Can it really charge 12 cells using a 12V lead acid battery for power? Tfour2 Batteries and Chargers 7 Nov 06, 2002 02:21 PM
Wattage pf-12 and how to charge Coop Batteries and Chargers 1 Oct 18, 2002 06:23 PM
WattAge PF-12 AC/DC Peak Charger? rtucker Parkflyers 3 May 01, 2002 07:08 AM
Wattage PF-12 Charger JCMcLean Power Systems 1 Apr 23, 2002 11:35 AM
