Old Jan 02, 2008, 12:03 PM
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Best ES CG for FPV purposes
What are you guys with some time on the systen using for CG. Are you using the factory recommended 5mm from the back edge on the spar cover or further forward? If the stock location are you balancing it to be level or pitched down?
Gary Evans is offline Find More Posts by Gary Evans
Old Jan 02, 2008, 02:56 PM
Heli addict
Joined Feb 2007
I found out that factory recommended CG position gives the ship slowest gliding speed. If CG position goes further forward the gliding speed will be more in order to keep plane level. But if CG goes a bit back then plane tend to stall and elevator needs to be trimmed down.
vladz is offline Find More Posts by vladz
Old Jan 02, 2008, 03:10 PM
Mesa, Arizona
Joined Nov 2006
I currently have my CG at the factory recommended 5mm and have had to add down elevator trim just to avoid straight and level stalls. I think its still flying too slow hence my wish to hear what others have found to work for FPV.
Old Jan 02, 2008, 04:07 PM
Joined Oct 2006
LOL....I just put my FPV System on and fly!
Domoson is offline Find More Posts by Domoson
Old Jan 02, 2008, 04:09 PM
Mesa, Arizona
Joined Nov 2006
LOL... Really! What kind of ship is that where CG isn't important. A balloon perhaps?
Old Jan 02, 2008, 05:05 PM
Joined Oct 2006
All of my FPV Ships.....I Just put the stuff on and Fly
Old Jan 02, 2008, 05:20 PM
Joined Feb 2004
I have flown several ESs and found that if I balance the wing right on the leading edge of the spar box that works best for me. My FPV ES weighs around 30 oz and it flies slowly enough for me.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Jan 02, 2008, 05:22 PM
bulldozerr
Manchester, Connecticut
Joined Nov 2007
Yup, Yes he does lol
bulldozerr is offline Find More Posts by bulldozerr
Old Jan 02, 2008, 05:37 PM
Mesa, Arizona
Joined Nov 2006
Wow! Thats major change from 5mm in front of the rear of the spar box. As suspected I may have my CG way too far back.
Old Jan 02, 2008, 05:40 PM
Joined Oct 2006
My EasyStar is very nose heavy....thats why I put a brushless on..to handle the weight.
Old Jan 02, 2008, 07:03 PM
Joined Feb 2004
If you set it up with the cg like in the directions it will do what the video on Hobby Lobby shows and that is climb under power hands off. You will have to fly it to the ground depending on how heavy it is and that's what I found. I had a stock one I set up for one of my kids and I experimented with it and found it actually flew a lot smoother with the cg set at the leading edge of the spar box.
Old Jan 06, 2008, 08:06 PM
Joined Feb 2004
Here's how mine flies at 31.5 oz AUW and with the cg set on the leading edge of the spar box.
Easy Star FPV Plane Flying From Pavement (1 min 56 sec)
Old Jan 07, 2008, 01:31 AM
Mesa, Arizona
Joined Nov 2006
Nice runway! I moved my CG up to 5mm behind the front edge of the spar box and all of the handling problems were solved. Surprising the CG issue for the heavier FPV ships hasn't seen more light. Thanks for the suggestion.
best performing cg for photon 1 wing warrior Hand Launch 2 Dec 02, 2004 12:41 AM
Best CG for hovering Shock Flyer? CactusJackSlade 3D Flying 2 Jul 11, 2004 12:28 AM
Best way to determine CG for GW spitfire? mattski GWS (Grand Wing Servo) 4 Sep 13, 2003 06:14 AM
Rave Best CG for Thermal Duration? Lewis Adam Sailplane Talk 3 Apr 16, 2003 11:28 AM
Best performance CG for Omega 1.8 and Tango gliders??? jshelton Electric Sailplanes 4 Dec 17, 2001 02:02 PM
