Old May 23, 2014, 10:54 AM
latinajet's Avatar
Joined Feb 2011
Let's Talk about the Most Efficient Setups 64 -105mm Amps/Thrust to Wallet/Costs!
Hey everyone post your findings for the most efficient and friendliest to your wallet with the most wow factor!
64mm Lander shroud wemo mini 64 rotor Tppower/lander motor 4300kv $75.00
64mm (5 Blade) + IR550 4300- 4.0mm Motor + 14.8v Static Thrust: 2lbs 13oz. 55A 825w
64mm (5 Blade) + IR550 4300 -4.0mm Motor + 18.5v Static Thrust: 4lbs 01oz. 80A 1440w Run at your own risk!
70mm Fans
70mm rclander/Tppower 2400kv CSV3/XRP 9 stator 10B $75.00
70mm (10 Blade) + 2400kv -4.0mm Motor + 14.8v Static Thrust: 2lbs 12oz. 50A 750w
70mm (10 Blade) + 2400kv- 4.0mm Motor + 18.5v Static Thrust: 4lbs 2oz. 70A 1400w
70mm (10 Blade) + 2400kv -4.0mm Motor + 22.2v Static Thrust: 6lbs 5oz. 90A 2100w
80MM Fans very light setups over the 36mm motors units out there!
1. Eflite Stock setup 2150kv and 5b rotor
2. Eflite shroud, 1700kv Het 28mm motor, 10B rotor by Haoye
3. Hoaye Shroud, 1700kv TP/Lander, and Hoaye 10B
80mm deltaV32 + 5B Rotor + 2150kv eflite motor = Static Thrust 5.40lbs @ 55a 1400w 6s lipo $105.00
80mm Eflite Shroud + 10B Rotor + HET 1700kv = Static Thrust 6lbs @ 70a 1600W 6s lipo $150.00
Haoye 80mm Shroud + 10B Rotor + Lander 1700kv = Static Thrust 6lbs @ 77a 1600W 6s lipo $$102.00
90MM
Hoaye 90mm 12B +HET 1400kv + 6s = 5lbs 12oz. @ 67amps $130.00
Hoaye 90mm 12B +HET 1400kv + 8s = 9lbs 6oz. @ 90amps 2700w $130.00 Cheaper if use a TP/lander
105MM Taft/Changesun
CS 105mm/Taft J10 fan 1350kv 3684 inrunner + 6s lipo = Thrust 7lbs 10oz. @ 78 amps $155.00
latinajet is offline Find More Posts by latinajet
Old Jul 28, 2014, 10:33 PM
Oshkosh, WI
Joined Nov 2002
Hey, latinajet! do you know where I can find bench top static test data for the change sun 105 fan? TIA!
Phil
PhilLin is offline Find More Posts by PhilLin
Old Jul 29, 2014, 05:07 AM
United Kingdom, England, Southampton
Joined Oct 2013
There are no 'Superfans'
Size for size, including the expensive Schubeler fans with an integrated, purpose designed motor, their efficiency is all much the same. Put the same number of watts in and you will get the same thrust out. Near enough.
Small fans, say 70mm, are not as efficient as 90mm ones, which in turn are not as efficient 120mm ones, etc.
And inrunner motors are more efficient than outrunners, the quality (tightness of windings, strength of magnets, etc). being the same.
The most important thing is matching of the motor to the fan. And motors should stay as cool as possible. Heat, even dissipated with a heatsink, is just wasted power. And current, not voltage, makes the motor hot. So go for a low Kv motor and use a high voltage, The current (thus heating) will be less.
Mark Powell is online now Find More Posts by Mark Powell
Reply With Quote  (Disabled)
Old Oct 10, 2014, 02:04 AM
Australia, NSW, Albury
Joined Jul 2010
Inrunner Vs Outrunner
Does this contradict inrunner Vs outrunner in propeller applications ? Please explain why.
plasticbaldy is offline Find More Posts by plasticbaldy
Old Jan 18, 2015, 05:38 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
True, LJ should have made the title "cheapest that will do the job" as he obviously dislikes anything that costs a few $$, referring to them as "POS"
Baldy, don't know if it contradicts anything, is it proven outrunners are better than inrunners with props? Seems the best pylon racers and speed machines run inrunners too
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 19, 2015, 01:41 AM
Joined Oct 2013
Depends on what you want it for. Inrunners are inherently more efficient than outrunners but don't have so much torque at low revs so you might have to use a gearbox if you want to drive a big prop. This will lower the efficiency. Pylon racers tend to use small props so don't need the gearbox. A powered glider with a big prop will need one if you use an inrunner, but a high-quality setup (I use Kontronik for such planes) might still be better than the 'average' cheap outrunner.
Costs:
Sometimes higher costs have to be accepted. You cut corners the performance is lessened. EDFs are hard enough already.
Personally I have grave doubts about the safety of some of these very low cost Chinese fans. Particularly if you run them way above any specification they might have. Which we all tend to do. And it's not just safety. If they come apart they will destroy your plane too. And I would rather spend 200 dollars on something that works rather than 100 dollars on something that doesn't.
And toy planes aren't part of your pension scheme anyway.
(BTW: You can't quote me at the moment because I have been what the mods apparently think is excessively 'direct' a couple of times )
Old Jan 19, 2015, 09:06 PM
Ontario, Canada
Joined Jul 2005
LOL!! Too funny!
I get the same comments from time to time.
Take it as a compliment.
pylonboy is offline Find More Posts by pylonboy
Discussion Lets talk about 'smart' phones and providers... UlteriorModem Life, The Universe, and Politics 95 Mar 14, 2014 02:23 PM
Question Most efficient way to get 200g of Thrust soccer du25 Multirotor Electronics 1 Mar 02, 2014 01:56 PM
Discussion Lets talk about recovery devices for down multirotor 1sq Multirotor Talk 4 Dec 29, 2013 08:04 PM
Discussion The it's too quiet In Atlanta/ lets talk about HHAEFI thread! electrich Atlanta Area RC 76 Oct 11, 2013 06:06 PM
Idea Lets talk about EPP baby, lets talk about PU/RT Drusky Slope 11 Jun 09, 2007 01:30 PM
