Old May 09, 2014, 05:25 PM
United States, PA
Joined Feb 2013
I like this one a lot. sounds pretty accurate. What's next on the list? Did you make the Smart Phone version yet?
HD
Heavy_Duty is offline Find More Posts by Heavy_Duty
Old May 13, 2014, 12:43 PM
Dutchraptor's Avatar
The Netherlands, ZH, Hoogvliet
Joined Jul 2008
For those who want to control/change/update the raspi when it is actually in the boat.
  1. connect the raspi to your network and let it boot up.
  2. Install putty and connect with the ip-adress of the raspi. http://www.putty.org/
    • default name: pi
    • default pass: raspberry
  3. Follow the instructions on the site: http://www.penguintutor.com/linux/tightvnc
  4. I didn't bother with the securing part of the site. When I installed the client for windows, it worked OK. I even didn't use the password option. It's not that my boat is connected to the internet all the time.
    • it uses the password from the raspberry
I didn't make a ini file, just used the downloadable version from the site.
Dutchraptor is offline Find More Posts by Dutchraptor
Old Jun 14, 2014, 06:48 PM
ISCOLD
Joined Mar 2014
Blutoh,
I can not start the sounds with codes 21032 e 21016. The others sounds of engine are ok.
Regards
Iscold
Iscold is offline Find More Posts by Iscold
Old Jun 15, 2014, 10:29 AM
ISCOLD
Joined Mar 2014
Friends,
Can someone help me to edit the archive soundfx.ini ?
Iscold
Old Jun 15, 2014, 10:36 AM
---o-O-o---
blutoh's Avatar
United States, NJ, Livingston
Joined Mar 2012
Hi Iscold,
Start Engine 2: command: 21032;
In the file " soundfx.ini", Make sure that you have the number of engines set to 2. It should look like this:
engines: 2
If it is not set to 2, code 21032 won't do anything because there is not a second engine configured.
Start Ambient Sounds command: 21016;
This plays the ambient (background) soundfx.
Make sure you have a file named ambient.ogg in the directory: /home/pi/soundfx/data/
If it's missing or corrupt nothing will play, I have attached a copy below. Unzip it and put it in: /home/pi/soundfx/data
blutoh
blutoh is offline Find More Posts by blutoh
Old Jun 15, 2014, 10:57 AM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
Hold on, I will post a version with the correct settings in a little while.
Old Jun 15, 2014, 11:19 AM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
Try this one.
Old Jun 15, 2014, 09:14 PM
ISCOLD
Joined Mar 2014
Blutoh,
I compile the Dutchraptor code and charge it on Arduino UNO.
I change the archive soundfx.ini in Raspberry using FileZila software.
I am using "putty" to communicate with Rasp by network. When I start mnuSoundfx.py I can hear something like "I,I,sir" and when start 11000 , I can hear gas engine sound on speakers, but nothing with commands 21032 and 21016.
I am using an Arduino Uno connected to Rasp by USB cable. When I switch on, I can hear something like "I,I,sir". Then I conclude that autostart is OK.
But, when I press any command pushbutton there is no sound on speakers. The TX led on Arduino blink.
I think the problem is the communication between Arduino Uno and Rasp.
I will continue to try on my system.
Regards
Iscold
Old Jun 15, 2014, 11:52 PM
Joined Jul 2008
Iscold,
Did you allready try to look up the actual name of the arduino woth: dmesg | grep tty
It looks like a communication problem. On the other hand, if the 21032 sound doesn't work with putty, there might be another problem like a corrupt sound file or the sounds are in the wrong place. When you use another sound command, does that work?
When there is a communication error like that the wrong tty, the autostart will work and it will say I I sir, but then quits.
Danny
Old Jun 16, 2014, 06:53 PM
ISCOLD
Joined Mar 2014
Dutchraptor,
Did you allready try to look up the actual name of the arduino woth: dmesg | grep tty Sorry, but I can not understand the above statement.
Yes, I think this is a communication problem. I try to edit the soundfx.ini archive and change the communication port. I change for ttyUSB1 and nothing happens. Then I change back this archive.
Yes, when I use all engines commands (each rotation) all is OK.
The next step will be erase all archives in Rasp and install again.
Regards
Iscold
Old Jun 16, 2014, 06:57 PM
ISCOLD
Joined Mar 2014
Dutchraptor,
I missing to say that all engines sounds goes to speakers only when I am using putty.
By Arduino UNO no sound.
Iscold
Old Jun 16, 2014, 11:55 PM
Joined Jul 2008
Just out of curiousity. Did you add the reset/kill button? try to disable it in the arduino sketch-file. You do need to have the switches in the boat for the engines, ambient and crew. The other functions are an interpretation from the transmiter channel.
To check which commands are send from the arduino, you can hook it up to your normal computer and use the serial monitor to see what it receives. If you're not using the remote switchable sounds, comment them out (with a //). They will otherwise be kept send and hogging up the line.
good luck
Danny
Old Jun 18, 2014, 05:12 PM
Printpix2014's Avatar
Mexico
Joined Jun 2014
Hola........es muy dificil estos proyecto por donde empiezo??: Palomitas:
Saludos!!
Printpix2014 is offline Find More Posts by Printpix2014
Old Jun 18, 2014, 06:40 PM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
Perdone mi mala español Printpix2014, estoy utilizando una aplicación de traductor. Empieza por el principio. ¿Ya tienes una pi frambuesa? Si es así lo primero que debe hacer es intentar la instalación, consulte el post # 301 para los detalles, sobre todo en el archivo "readme.txt".
Old Jun 20, 2014, 12:21 AM
Mexico
Joined Jun 2014
goodnight blutoh just bought Raspberry Pi first I will try to post 301 ...... Thanks!
Greetings!
