Old Feb 07, 2013, 05:36 PM
cwolfe's Avatar
United States, TX, Spring
Joined Aug 2011
OK, I'm thinking of getting a multi-rotor.
Been flying planes for about 1 1/2 years. Not long I know. I have 10 planes of various sizes.
I'm wondering how difficult multirotors are to fly? It seems that once you get them dialed in they're pretty simple to fly.
The thought of FPV intrigues me.
One thing that has really stumped me is how do they navigate. Does the onboard mother board tell the motors on one side to slow down and the ones on the other speed up to turn?
Should I get a kit like an F550 or such?
Anyway thanks for any advise.
CW
cwolfe is offline Find More Posts by cwolfe
Old Feb 07, 2013, 06:45 PM
Head full of foam
United States, NE, Omaha
Joined Jan 2013
You mean yaw?
In a quad two motors, across from each other diagonally, are spinning the opposite direction of the other two. Speed one set up and slow the other down and the lift stays the same but you have a difference in torque on the arms they're mounted on. That difference causes the craft to yaw. If you sped up one side and slowed the other, as you suggested, the thing would just flip over.
The worst part of piloting LOS is that they are symetrical. Without lights it's hard to tell which end is the front at a distance. Add to that the fact that they'll be just as happy to fly backwards as forwards and it complicates it even more. It's not like a plane where you can look at the direction it's moving and work out which end is the front...
As far as an F550... for me that path was a mistake. I went Blade mQX -> F450 -> cheap wooden tricopter. My 4th take off with the F450 had it sailing towards some metal railing, barely managed to stop it in time. It's too expensive for my skill level, enter the cheap wooden tri to beat around. With some experience like you have, I don't know, up to you. I would suggest not getting something off the shelf RTF. The F450 came as a kit with frame, motors, esc's and props. I still had to assemble, wire, install RX, FC, camera & vid TX, and tune a bit. That's enough to get you to the point that you can fix what you break, and you will break things.
Also, you can FPV your planes. Plenty of people doing that.
RuralFPV is offline Find More Posts by RuralFPV
Old Feb 07, 2013, 06:59 PM
cwolfe's Avatar
Joined Aug 2011
Thanks RuralFPV.
I agree a kit would be the way to go. I like building anyway and the knowledge helps when it comes time for repairs.
It looks like you can put one together fairly reasonable using HobbyKing. Of course I would take a chance on the quality, but I do that with plane gear anyway.
Just testing the waters. Always looking for something new.
CW
Idea Multi Rotor Racing (FPV or else) crashtested Multirotor Talk 45 May 13, 2013 02:08 AM
Discussion My First Multi-rotor... more appropriatly... vstrandberg Multirotor Electronics 0 Jan 12, 2013 10:29 AM
Sold HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA) sixstringlz Aircraft - Electric - Multirotor (FS/W) 2 Jan 09, 2013 11:15 AM
Discussion Thinking of getting into multi-rotors - a couple of questions. TheNiceGuy Multirotor Talk 25 Dec 17, 2011 08:20 AM
Question Ok...I think I'm getting it Fly-n-hi Batteries and Chargers 7 Mar 21, 2009 07:28 PM
