Old Nov 10, 2012, 11:03 PM
Joined Oct 2012
Wind sensor
Anyone know a good, cheep, light weight, wind sensor with digital output?
This is going on an autonomous sailboat. We need to know wind direction. Not so much speed.
joeblinky is offline Find More Posts by joeblinky
Old Nov 10, 2012, 11:26 PM
Fokker Ace's Avatar
Joined Aug 2006
You asked a month ago and there were responses:
http://www.rcgroups.com/forums/showthread.php?t=1747380
Fokker Ace is offline Find More Posts by Fokker Ace
Old Nov 11, 2012, 12:41 AM
Joined Oct 2012
Thank you, somehow I overlooked that. I should also clarify in case anyone responds to this one I need a wind vane. I think sensor was misleading and makes you think we need to know the wind speed.
Old Nov 11, 2012, 01:20 AM
United States, CA, Alameda
Joined Nov 2010
Wind vanes are really expensive and for a 2mtr boat, would have to be custom made. Monitor and scanmar both make wind vanes. Sounds like you will need to increase your budget. Ryan
Rssailor is offline Find More Posts by Rssailor
Old Nov 11, 2012, 06:33 AM
Blackpool, Lancs
Joined Feb 2006
A small wind vane should be no problem. Its basically a feather on a spindle that is free enough to tend to always point downwind. On something like a yacht that rocks, it would probably need a counterbalance to reduce any tendency to point downward, especially making the assumption that it would be mounted at the top of the mast.
The problem is reading the direction, which would need something low mass and low friction that is capable of continuous rotation without running into an end stop. The only thing that springs to mind is a disk with binary encoding holes and a sensor for each ring of holes. 8 rings of holes, definition is 256 steps for full rotation, or one and a bit degrees. The follow on problems are getting the power requirement down to a viable level and minimizing the weight..
mfr02 is offline Find More Posts by mfr02
Old Nov 15, 2012, 03:00 PM
Joined Oct 2012
There are potentiometers available online that are 360 degrees of rotation as small as 1/2" in diameter that are waterproof. They aren't cheap. You could utilize that to monitor the voltage increase or decrease to give you the actual voltage where the "vane" is. This would then allow you to calculate the degree's of apparent wind.
We are working on something similar to be read off a digital 2.4Ghtz radio system to get wind direction and speed. Much simpler if you don't need to broadcast it through existing radio equipment.
iBoat is offline Find More Posts by iBoat
Discussion Wind Sensor joeblinky Sailboats 5 Nov 11, 2012 05:12 PM
Sold NEW Spektrum AR8000 Rx w/ Sat. + TM1000 + voltage sensor + Temp Sensor $149 Winterdd Aircraft - General - Radio Equipment (FS/W) 1 Mar 13, 2012 06:17 PM
Question Ultrasonic wind speed & Direction sensor Irish Steve DIY Electronics 1 Dec 30, 2011 03:32 AM
Help! Heading sensor and wind calcs KiloOne Eagle Tree Systems 1 Jun 18, 2008 10:52 PM
Wind Wind Wind Wind Wind Wind Wind Wind!!!!!!!! kansascloud Parkflyers 44 Apr 09, 2002 10:02 AM
