Old Dec 08, 2014, 04:57 AM
Joined Jun 2013
I did calibrated all sensor by multiwii config 2.3, I arm the stick and see in GUI, all motor indicate the same value = 1000, I push the stick throttle 1 level D2, D3 D5 and D6 first time as the same indicate 1150, sfter that D6 always increase the power until 1250, and D5 as follow increase the power to. Any Solution again
danil mahendra is offline Find More Posts by danil mahendra
Old Dec 08, 2014, 06:42 AM
Son, Norway
Joined Sep 2004
You didn't answer if this is also the case without any mode, like Level or Angle, switched on.
flarssen is online now Find More Posts by flarssen
Old Dec 08, 2014, 08:35 AM
Joined Jun 2013
D6 spin faster
Ok Fred, I did to calibrate the sensor as follows as your suggestion, but result D6 always spin faster then other, http://static.rcgroups.com/forums/im...s/confused.gif, Did you ever try Red HK mtw Pro to build quadcopter ? its hard to me to fix it, could you share more fred... thank you
Dida
Old Dec 08, 2014, 02:10 PM
Son, Norway
Joined Sep 2004
Dida
I have it in a hexacopter. I haven't changed any PID-settings. Still not sure how yours behave without any modes that uses ACC sensor. Does the motor outputs react correctly if you tilt the quad by hand?
Old Dec 27, 2014, 11:25 PM
United States, FL, Gainesville
Joined May 2014
Does it matter which way the gps board is turned when mounted? The FC usually has a direction to be mounted on craft and was wondering about the gps for the mwc
dwroberts66 is offline Find More Posts by dwroberts66
Old Dec 28, 2014, 02:45 PM
Austria
Joined Jan 2004
unless you use the on board mag present in some gps module ... direction does not play any role
e_lm_70 is online now Find More Posts by e_lm_70
Old Dec 31, 2014, 02:20 PM
Joined May 2014
thanks e_lm_70
Discussion MultiWii on HK MultiWii Mega Board WITH MTK 3329 GPS TheFernMan Multirotor Electronics 2363 Jan 23, 2015 10:24 PM
Discussion HobbyKing MultiWii SE V2.0 Flight Controller Erknie Multirotor Electronics 109 Aug 18, 2014 06:01 AM
Discussion Has anyone tried the new HobbyKing MultiWii SE V2.0 Flight Controller w/FTDI rernewe Multirotor Electronics 2 Jun 09, 2014 11:07 AM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 05:28 AM
