Old May 23, 2015, 07:18 PM
Zeroeffect is offline
Find More Posts by Zeroeffect
Joined Feb 2015
Fatshark teleporter kit, switching to another cam?
I have the Fatshark teleporter V3 kit. If I changed to a 600 TVL Sony board cam would that make the picture better?
It seems that CMOS camera isn't very good.
Also would I be able to utilize the rest of the Fatshark system for power? Could I hook up a new camera the same way the pilot HD is currently setup?
Zeroeffect is offline Find More Posts by Zeroeffect
Old May 24, 2015, 12:29 PM
DanT is online now
Find More Posts by DanT
DanT's Avatar
United States, TX
Joined Feb 2006
A little but you don't have the lines in goggles ? You have only 320x240 lines in your display.
Your goggles have very little lines built into them.[B] Headset: 25 degree FOV QVGA (320x240 lines) display
More lines = better video and picture with more detail !
Example FatShark Attitude V2 goggles have Fov 35 degree and VGA, 640X480) more lines better video picture!
With Adjustable IPD 59-69mm for eyes
The camera that comes with this kit is also IMO bad .
Using better antennas and getting a better camera will help some!
IMO if your going to keep this combo kit, start with better camera and antennas .
DanT
DanT is online now Find More Posts by DanT
Old May 24, 2015, 02:59 PM
Joined Feb 2015
Thank you. I'm still new at all this. I'm going to try a better camera and some antennas.
Old May 24, 2015, 04:19 PM
Heppy Ket is offline
Find More Posts by Heppy Ket
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
This is a good camera that will fit the voltage requirements of Immersion / Fatshark transmitters perfectly, you will of course benefit from a higher resolution in your goggles, but you will see an improvement. You will need to tweak the settings of the camera to get the best out of it.
http://www.securitycamera2000.com//p...PV-Camera.html
It now comes with a nifty metal casing and works well, looks like this ....
Flight Camera St Kilda (11 min 32 sec)
Heppy Ket is offline Find More Posts by Heppy Ket
For Sale Fatshark Teleporter Goggles & Pilot HD Cam & IRC - 5.8 GHz SpiroNET Omni SMA Antenna Bionic420 FPV Equipment (FS/W) 2 May 07, 2015 04:58 PM
Sold Fat Shark Teleporter V3 kit w/ transmitter and cam js81_99 FPV Equipment (FS/W) 2 Dec 30, 2014 11:26 AM
Sold NIB Fatshark Teleporter V3 - FPV system- Goggles, Batt, Trans, Cam - $180 OBO (34997) wilanz FPV Equipment (FS/W) 2 Jul 07, 2014 06:16 PM
Sold Brand new never opened Fatshark Teleporter V3 kit and the new Spiro antenna set Syn_Ack FPV Equipment (FS/W) 4 May 21, 2014 10:06 AM
Discussion Newb Alert! Help with Fatshark Teleporter cam and ET OSD Pro djinni69 FPV Talk 1 Dec 07, 2009 11:28 AM
