Old Sep 24, 2012, 03:19 AM
maxmwill is offline
Find More Posts by maxmwill
United States, MI, Warren
Joined Nov 2011
Has this ever been modelled?
For quite a while, I've been wondering whether or not this aircraft has ever been modelled. The Heinkel HE 119. While it was a twin engine aircraft, both engine fed into one drive shaft, which turned the prop, making it theoretically a very clean flying machine.
It is also quite attractive.
About the only problem I could see in modelling it is the fact that the nose of the aircraft is also the canopy. Here is a link to a three view:
http://www.aviastar.org/pictures/germany/he-119.gif
Hopefully, this will be accessible.
As you might be able to see, this also had a float version.
If this has never been modelled before, I'm wondering if this'd be a doable project, as I think there has to be ventilation for an electric motor. Anyone have any helpful suggestions?
maxmwill is offline Find More Posts by maxmwill
Old Sep 25, 2012, 06:40 AM
heli_madken is online now
Find More Posts by heli_madken
Liverpool, England
Joined Jan 2005
It would be a really interesting project, I think I would be tempted to shaft drive the prop in the same way, place the motor behind the cockpit, although it says surface radiators where used for cooling there is a large belly scoop which you could use to cool the motor.
Never seen it modelled myself
heli_madken is online now Find More Posts by heli_madken
Old Sep 25, 2012, 07:21 AM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
Yes, it is interesting. However, if you want the clear cockpit area then the motor is pretty much at the wing leading edge and even with the batteries right behind it, the effective nose moment is awfully short. Certainly the weight of any cockpit detail would work in your favour!
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
Discussion Has this been done before (spectrum receiver in a Nextstar Ep ) rbgordon Beginner Training Area (Aircraft-Electric) 9 Sep 18, 2012 11:46 AM
Discussion Has this been done that anyone knows? dale4040 Waterplanes 30 May 26, 2012 06:56 AM
Discussion Berkeley Piper Comanche, has anybody out there built this model? Edubarca Vintage & Old-Timer Designs 0 May 10, 2012 03:05 PM
Discussion Has this guy been visiting our forum? Jim Thomerson Life, The Universe, and Politics 25 May 06, 2012 05:36 AM
Micro-Glider West Wings Swallow--Has anyone ever delt with this model? 525cj Scratchbuilt Indoor and Micro Models 2 Mar 31, 2003 08:31 AM
