Old Jan 05, 2010, 10:33 AM
jrb is offline
Find More Posts by jrb
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Prop response w/programmable curve?
JR 9303 lets you program a throttle curve, think of it kind of like Expo stick moves 0 25 50 75 100% , but real output signal does something like 0 12.5 35 60 100%.
Has anyone found a curve/profile that makes for a better plane/prop response to the throttle stick?
jrb is offline Find More Posts by jrb
Old Jan 05, 2010, 12:41 PM
freechip is offline
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Throttle curve is mainly used for helis as a way of setting the throttle to a specific point when the stick is position at a specific place on the TX.
Not really 100% usefull on a plane.
Throttle curve is very usefull for heli as the throttle stick not only control the motor speed but also blade pitch.
If you really wantto this because you really want the plane motor/prop to be spinning at a specific point in the throttle stick position then sure you can use throttle curve programming BUT that would still be user and rc preffered settings.
My curve may not work for you and your RC. So you are pretty sure on you're own.
Thats why several TX manufacturers have throttle curve programming on in heli mode if they have both heli and plane mode capability.
freechip is offline Find More Posts by freechip
Question HK SS esc's, programmable vs non-programmable. Jimmy JFlyer Power Systems 2 Dec 14, 2009 09:20 PM
Sold 12" Folding Prop w/4mm shaft hole $8 Mini Buzzard Aircraft - General - Miscellaneous (FS/W) 1 Dec 05, 2009 12:53 AM
Discussion No response from RangeVideo after numerous emails. restie FPV Talk 14 Dec 03, 2009 09:05 AM
New Product no 3rd or 4th prop, and it's not a co-ax: Vector bi-prop w/ outdoor video clip GaryGress_1 Coaxial Helicopters 23 Oct 06, 2009 10:56 AM
For Sale Walkera 4G3 Full Brushless W/ Programmable radio ren Aircraft - Electric - Helis (FS/W) 10 Sep 20, 2009 06:42 PM
