Old Aug 16, 2014, 04:26 PM
electriceddie is offline
Find More Posts by electriceddie
"Go Fast & Turn Left".......
electriceddie's Avatar
Joined Feb 2013
Help!
ESM - P-51B Mustang -"Bald Eagle"?
Hi Guys,
I just wanted to get some opinions about using an OS Max 1.20AX engine in the ESM - P-51B Mustang -"Bald Eagle"?
I am also thinking of the DLE 30 Gas engine as an alternate engine. I have anew OS Max 1.20AX engine with about 8-10 runs on it. I would like to use this engine and not have to lay out another $300.00 if possible, it seems like such a nice engine & very powerful. I had it in a "U-CAN DO 3D -60" & it had unlimited vertical performance. However I don’t want the engine to be marginal.
Manufacture Specs:
Wing Span: Approx. 71”
Fuse Length: 62.3”
Wing Area: 6.11sq. ft
Wing Loading: 33 oz/sq. ft
Weight Approx.: 13.5lbs.
Engine: 1.08 2 cycle -1.20-1.50 4-cycle or 26CC gas
Prop Recommendation: (For OS 1.20) 16x8 or 15x10
Would this OS Max 1.20AX engine with a - "J'TEC"-Radiowave In-Cowlmuffler, set up inverted, be a good choice? I don't want it to be marginal in where I need to run the engine at 75% to 100% full power just to keep the plane flying.
As per the specs, it says that the total airplane weight should come in at around 13.5 lbs. This is debatable...... I weighed out all the pieces of mine and mine came out to 15.4lbs. From what I have read in other threads this is in the same ball park as other ESM -P-51B planes.
Also if I go with the OS Max 1.20AX, I also need a recommendation for Prop sizes for this particular Warbird / Engine 1.20 OS Max setup. (If I choose to go this way)?
I have checked with OS, and OS Max recommends 16X8, 15X10. But I was looking for someone who may have a similar set up and which Prop Size, Brand & Type that worked well for them.
So what would you recommend? Go with the OS Max 1.20AX engine with a - "J'TEC"-Radiowave In-Cowl muffler? Or buy a new DLE30 size Gas engine; however keep in mind I do not want to sacrifice the plane but if the OS Max will fly it well, then Great…..
Thanks Guys
Ed
electriceddie is offline Find More Posts by electriceddie
Old Aug 16, 2014, 06:18 PM
RocketRobin is online now
Find More Posts by RocketRobin
Fox 1
RocketRobin's Avatar
Canada, AB, Calgary
Joined Jan 2013
Originally Posted by electriceddie View Post
Hi Guys,
Manufacture Specs:
Fuse Length: 62.3”
Thanks Guys
Ed
Hi Ed,
Since this is the "electric" bit of the forum I'm going to suggest you use a Rimfire 1.20.
Cheers!
Rocket
RocketRobin is online now Find More Posts by RocketRobin
Help! ESM - P-51B Mustang - "Bald Eagle" - Building & Specs Questions - Please Help!!! electriceddie Scale ARF/RTF 3 Mar 24, 2014 09:28 AM
Help! ESM - P-51B Mustang - "Bald Eagle" - Building & Specs Questions - Please Help!!! electriceddie Fuel Warbirds 0 Mar 02, 2014 05:19 PM
Help! ESM - P-51B Mustang - "Bald Eagle" - Building & Specs Questions - Please Help!!! electriceddie Scale Fuel Planes 0 Mar 02, 2014 05:16 PM
Discussion ESM - P-51B Mustang - "Bald Eagle" Help!!! I need factory paint colors electriceddie Fuel Warbirds 3 Mar 01, 2014 11:39 AM
Help! ESM - P-51B Mustang - "Bald Eagle" Help!!! I need factory paint colors electriceddie Scale ARF/RTF 0 Feb 23, 2014 07:57 PM
