Old Feb 21, 2013, 03:49 AM
GBLynden is online now
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
Starmax F-18 EDF Jet (Blue Angel Paint)
I have to start off by saying I have been flying RC for about two years now and I love it!
My second plane was this jet and needless to say, it has been to hell and back. As a tribute to it, I am going to post a few videos I have of its flying history including a nasty crash that took place where it busted the canopy off and it still flew like a champ!
This is the very first recorded flight I made with it and only the second successful flight. The video is a little crude, but I am proud of it. The videos do get better as does my flying with it:
StarMax 64mm EDF F-18 Super Hornet Blue Angel - Third Flight Different Angle - Part I (1 min 21 sec)
Here is a really cool look at it being hand launched:
RC F-18 Super Hornet Quick Flight at Dusk. (1 min 27 sec)
Here is a the crash after a bad hand launch:
F/A-18 64mm EDF Jet Crash on Take-Off in HD (0 min 53 sec)
Here is a the flight immediately after with no canopy on it with high speed low passes:
RC F-18 Low Passes (2 min 33 sec)
The final video is a look at how it handles wind. With is its achilles heel for sure:
RC F-18 Dancing in the Wind (2 min 32 sec)
I am extremely pleased with my $109 Banana Hobby purchase. Everything is holding up after being abused and I couldn't be any happier with this plane!
Thanks for viewing and please feel free to share your pictures and videos to compare and contrast this with other EDF's.
GB
GBLynden is online now Find More Posts by GBLynden
Old Feb 21, 2013, 06:17 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Great work GB
Another modeler caught the EDF bug!
If you like this version, you should try one of the 90mm size F-18's. They fly great!
4stripes is offline Find More Posts by 4stripes
Old Feb 21, 2013, 07:06 AM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Really great vids, GB! More fun than peanut butter under a dog's lips!
Amazing range of speeds for this plane; looks like you can slow it to a walk. What did Banana put in it for power? (I.e., motor kv, battery)
PikeStaff is online now Find More Posts by PikeStaff
Old Feb 21, 2013, 07:30 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
try 70mm F-18: Correction: not Speed passes.... it's low altitude passes.... lol.
F 18 JR 3D 70mm flight (3 min 59 sec)
viperviper is online now Find More Posts by viperviper
Old Feb 22, 2013, 05:52 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Originally Posted by 4stripes View Post
Great work GB
I did for sure! I am not sure I would be about to handle a 90mm, but I may look into that for my next jet. What kind of charger do you use for it and what is the suggested battery?
It is a pretty solid plane for sure. The wind helps with the slow walk, but I also have it tuned just right after much trial and error.
It has a 64mm EDF fan and it runs on a 25c 1,300 mah 3S battery. I am not sure about the motor kv. It is listed as a 14L linear brushless motor.
http://www.youtube.com/watch?v=ygIrYz4Uth0
Very fair point and WOW! What great flying!!!
What do you have in that thing?
GB
Old Feb 22, 2013, 11:13 PM
Antarctica
Joined Apr 2012
GB
Leopard 3400KV motor with CS 10 blade fan unit. Running on 4S 4000mah!
Old Feb 23, 2013, 06:22 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
I have a few Starmax F-18s that I have had for years. Great flying airframe. at some point, pull the esc and fan/motor. Upgrade to a 4800 KV motor and 40A esc. Performance will really step up. You can still use 1300 mAh 40C lipos to keep the balance.
Joe 1320 is offline Find More Posts by Joe 1320
Old Feb 24, 2013, 04:23 AM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Thank you for the suggestion Joe! Any specific suggestions for where to get something like those items and which ones you use?
GB
Old Mar 10, 2013, 01:52 AM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Here is my latest video with my jet. I am pushing the limits of my skill a little bit doing these stunts and tricks, but it is fun
Stunts and Tricks with the Blue Angel F-18 Hornet 64mm EDF Jet (4 min 19 sec)
Old Mar 10, 2013, 05:01 AM
Antarctica
Joined Apr 2012
[url]]
nice video, but i thought it will be good if u hv not extended the landing gears since the field grass is patchy and thick. it will ripped off your retracts. May be u can try landing on tarmac road, and probably maintaining 10-20 % throttle input while landing will be good too...else the jet will just lost lift and slam down resulting in a heavy landing.... cheerS!
Old Mar 10, 2013, 07:34 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
GB
I have used several different configurations in several of my Starmax jets. I believe the best "middle of the road" setup is to use a stock 5 blade fan, a 4800 kV out runner and a 40A esc for high rpm use. a 2200 Mah lipo rounds it out and you"ll find your new configuration has much better vertical performance, speed is better and the jet carries the weight very well. I do remove the divider between the two underside compartments and make it one long battery tray. There is a conversion batter tray available that is made out of ply, I may have an extra one or they are available from pmpjohn here on the forums. You could still use 1300 mah lipos but they better be 40C discharge or you will cook them quickly. Expect about a 38A load at wide open.
Old Mar 12, 2013, 06:17 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Thanks!
That is great advice! The problem is that the landing gear is fixed and is already damaged, so I am just going to run them into the ground. It would surely damage the airframe if I tried to land on pavement because it would roll. I hand launch it because the front gear is already damaged and it is not controllable on the ground. The good news is that this is essentially my "Trainer EDF" and I have a new kit ready to be put to use as soon as this one can't hold up any longer. I will use the new one as you described as I want to keep it healthy as long as possible now the most of the learning curve is complete.
It is actually fun to have a "beater EDF" to take risks with
Thank you again for your post!
GB
I just tried out my new 1300 40C battery in this latest video and I did notice much better performance for sure!
The point about it carrying weight well is a good one. I have so much extra epoxy weight holding this thing together, it isn't even funny. It still flies extremely well and it has been one of the best RC purchases I have made, in spite of all of the ups and downs I have had with it.
Thank you for your information on this. It is very helpful!
GB
Old Apr 15, 2013, 11:46 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
I took my out today in the wind and did some scale flying. I am extremely happy with how the video turned out!
Scale Flying with my Blue Angel F-18 Hornet 64mm EDF Jet Plus Bonus Take-Offs and Landings (4 min 54 sec)
Old Oct 20, 2013, 11:20 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
I have recently only flown my newest EDF jets and as a result left this great plane on the shelf at home. That all changed today and I am pretty sure that I won't be leaving this jet at home much in the future as a result. Even though I crashed into a bush a full speed (see the video), I had a great time!
Enjoy!
RC F-18 Super Hornet 64mm EDF Jet Plus Bonus RC Jet Crash Full Speed Into a Bush (3 min 35 sec)
Old May 17, 2014, 01:03 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
I did my best to put on an air show for all to enjoy with this video! This is the BlitzRCWorks StarMax RC F-18 EDF jet in the Blue Angel paint scheme.
My good friend John captures it all on video using the great zoom on my camera with many of the highlights!
F-18 RC Jet Take-Offs and Landings in Berry Field at Sunset - RC Plane Fun (3 min 9 sec)
PS: I know the landings were not good, but I put them in there anyway for fun lol
Sold STARMAX F-18 64mm Blue Angels - $75 Supersteve Aircraft - Electric - Jets (FS/W) 3 Feb 09, 2013 07:41 PM
Question HK Blue Angels Micro F-18 EDF Jet (new video) Arxangel Scratchbuilt Indoor and Micro Models 7 Oct 21, 2012 02:45 PM
Discussion Hobby King F-18 Blue Angels EDF Plug-n-Fly RC Jet Airmaster23 Foamy EDFs 0 Dec 20, 2010 10:26 AM
For Sale Starmax 90mm EDF F/A-18 (Blue Angel) NEW IN BOX gary0307 Aircraft - Electric - Airplanes (FS/W) 5 May 05, 2010 11:13 AM
