Old Mar 16, 2012, 01:08 PM
zhavener is offline
Find More Posts by zhavener
United States, GA, Athens
Joined Feb 2012
Floating Ground on an ESP114A
I have seen the post showing how to float a ground on a standard ESP114 PSU
The ESP114A has a slightly different PCB design and lacks the R381 location of its counterpart.
There are 6 screws that connect the lower PCB to the case and it appears that two of them are for grounding (screws come in contatct with solder) IF I isolate both screws with fiber washers on the top and bottom am I headed in the right direction?
How would I go about with my DMM to prove to myself that I have indeed floated the ground? Ohms between case and DC Ground? power it up and test for voltage between 12vdc and case?
zhavener is offline Find More Posts by zhavener
Old Mar 16, 2012, 01:45 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I don't think you will insulate if you put fiber washer on top/bottom of PCB. Usually the through hole will have solder in/around it that can touch the screw.
I test case ground to 12V ground via ohm setting, then 12V + to case ground. Expect an open.
Rick
rampman is online now Find More Posts by rampman
Old Mar 17, 2012, 11:11 AM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
If you really need to put screws in the holes use plastic screws and of course fiber washers.
But can't you just leave them out?
Aren't there other screws holding the PC board in the case?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Mar 17, 2012, 01:00 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Cut the land between chassis ground and DC return on the bottom of the circuit board as shown in attached photo. Some have R381 and some don't (as you have determined). Those that don't need to have the copper land severed. Use either a very sharp knife or a dremel with a cutoff wheel (easiest and fastest). Verify isolation by probing with DMM or continuity tester.
Once you've done the above, there is no need for any isolation washers and chassis ground is preserved.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Apr 13, 2012, 07:55 PM
blackaa is offline
Find More Posts by blackaa
Ninjineer
Joined Dec 2011
I did this today, it worked exactly like described above. I cut the copper on the board just like the picture, tested continuity on that supply using the AC ground terminal in the back and the each of the 4 DC grounds had no continuity. Then I tested the unmodified supply the same way and obtained continuity between the AC Ground and DC Ground.
My question is, if I intend to run these two power supplies in series, do I need to do the modification to both of them? Is there a good picture of how the supplies are wired after this modification? I assume you no longer float the AC Ground, thus you connect a black AC grounding wire to both of the supplies AC ground terminal?
blackaa is offline Find More Posts by blackaa
Old Apr 13, 2012, 08:11 PM
RC Helicopter Pilot
Joined Mar 2010
No, Just one PS.
Sold BEST GROUND STATION DVR EVER...PERIOD! Make an Offer RChelisrule FPV Equipment (FS/W) 25 Jan 09, 2012 11:31 AM
Question Multiple Video Receivers on Ground Station. + Question on reception in fog! beaverlover FPV Talk 4 Nov 25, 2011 02:11 PM
Discussion Countering an 11x8 prop ground loop issue?? hidaven Electric Plane Talk 22 Nov 21, 2011 11:42 AM
Discussion ESP114 in series with ESP114A is okay, right? merzie Batteries and Chargers 1 Apr 25, 2011 06:36 PM
Discussion Ground Effect: Hovering the Walkera 4#3 close to an inch above ground EQMOD Micro Helis 1 Oct 12, 2008 05:38 PM
