Old Sep 18, 2011, 08:06 PM
Soarmark is offline
Find More Posts by Soarmark
Mark LSF # 3792
United States, TX, Garland
Joined Nov 2008
Ultracote Lite sticky problem
I just had to tear off a covering job on a rudder I had repaired. The Ultracote Lite had stuck to itself inside the rib bays and would not release before the structure started to deform. Thought I was done with my repair. Fortunately the rudder was unharmed.
When laying down the covering I noticed it would stick to itself much more aggressively than the Monocote I have used in the past. Is there some special trick that some one can tell me to keep it from sticiking to itself in very thin areas of the rib bays so I don't have it happen again?
Soarmark is offline Find More Posts by Soarmark
Old Sep 18, 2011, 08:50 PM
Norm Furutani is online now
Find More Posts by Norm Furutani
Norm Furutani's Avatar
United States, CA, Gardena
Had the same problem. I had some success with 3 solutions.
Try this first- using two pieces of masking tape(you don't want to make the problem worse), gently stick the tape on both sides of the covering and pull both sides apart.
#2 - Heat the problem area with a heat gun. If the bay is airtight, it should balloon up and separate.
#3 - If it still won't separate, poke a small pin hole in one side of the covering, near a spar or leading edge. Using air in a can, gently blow over the pin hole. Adding heat will help, but you will see where it was stuck together.
Haven't tried it, but I hear lightly dusting the sticky side with talcum powder helps. Dust it on, blow it off.
Good luck!
- Norm
Norm Furutani is online now Find More Posts by Norm Furutani
Old Sep 19, 2011, 01:47 PM
VegasRay is online now
Find More Posts by VegasRay
VegasRay
USA, NV, Las Vegas
Joined Oct 2005
Ultracoat Sticking to Itself
Soarmark - Norm's #2 works great for me. Just be careful when heating with the heat gun. I found that slowly making passes on both sides of the part (rudder for me) with the heat gun will cause the Ultracoat to balloon-out and gradually pull itself apart, while shrinking tight.
Caution - too much concentrated heat will burn thru the covering - keep the gun moving - go slow.
Hope this helps,
Ray
VegasRay is online now Find More Posts by VegasRay
Old Sep 19, 2011, 05:03 PM
Soarmark is offline
Mark LSF # 3792
Joined Nov 2008
Tried Norm's #2 solution to no avail as the ballooning was insufficent before the structure started to show the shrinking stress, even going slowly and heating both sides. Thus the removal of an almost completed covering job! If it happens again I may try option #1 since it was stuck prior to any heat being applied to the open bay area. Thanks for the input guys.
Mark
Old Sep 19, 2011, 05:42 PM
flystoolow is offline
Find More Posts by flystoolow
Joined Nov 2004
Just smear oil all over the place, including on your hands.
No problems then.
flystoolow is offline Find More Posts by flystoolow
Old Sep 19, 2011, 11:00 PM
marc 540 is offline
Find More Posts by marc 540
United States, IN
Joined May 2008
Just pull the covering tight enough so the covering will not touch itself. It can be done. If the glue sides touch each other it will not come apart even if only slightly warm. let one side completly cool before you add the other side.
Marc 540
marc 540 is offline Find More Posts by marc 540
Discussion Who has the best deal on Ultracote Lite/Oracover Lite xadmin Hot Online Deals 0 Feb 16, 2008 02:15 AM
Discussion Ultracote Lite vs. Ultracote icmartin Sailplane Talk 6 Apr 11, 2007 07:48 PM
Ultracote Lite vs SolarFilm Lite? Brill 1 The Builders Workshop 7 Aug 15, 2003 12:30 PM
WTB: Trans. Violet Oracover/Ultracote Lite byoung Aircraft - Electric - Airplanes (FS/W) 8 May 24, 2002 08:34 PM
Red color Oracover Lite vs. Ultracote Lite MMGM Electric Plane Talk 2 Mar 16, 2002 08:24 PM
