Old Jun 24, 2013, 08:16 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Build Log
The Joel "MetroGTI" Dirnberger H-Blu-O kit from RA Cores
This is a where the build instructions for Joel's Depron H-Blu-O kit will get roughed out. We released the kit at Warwick NY Fun Fly 6-22-2013
The kit is $34.95 for all the lasercut Depron parts and the horns and firewall and carbon fiber. We also offer the completer kit with the CF28-12 motor, 18 amp ESC and 3 9g servos for $39.95 so for under $75 you have everything you need to build the plane as shown.
You can find it on our website at http://www.racores.com/H-Blu-O.html
coreman is offline Find More Posts by coreman
Old Jun 24, 2013, 09:32 PM
BrownEyedFool is offline
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Rudder servo. Any compelling reason to have the servo arm penetrate the main wing and come out below. Looks like I could point the arm up rather than down and put the control horn above the wing. Would remove one more wing penetration/avenue of water entry.
BrownEyedFool is offline Find More Posts by BrownEyedFool
Old Jun 24, 2013, 10:02 PM
pcphill is offline
Find More Posts by pcphill
Plain Broke and Broke Planes!
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
Looking forward to it!
pcphill is offline Find More Posts by pcphill
Old Jun 24, 2013, 10:44 PM
MetroGTi is offline
Find More Posts by MetroGTi
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
At this point, take a few minutes and prepare the servos. Hook them up to a servo tester or receiver and with the travel centered, select the appropriate servo horns. Use the standard length, single arm horns for the elevons. Use a long arm for the rudder. Remove the labels from the sides of the servos that will be glued to the airframe to insure a strong joint.
During the trial fit and assembly of the rest of the airframe, there are a couple of things that can be done to ease the fit of the tabs into the slots.
First, clean out the slots with an emery board or sanding stick. You may find it advantageous to widen some slots slightly to ease assembly.
Second, slightly chamfer (bevel) the tabs so that they may be inserted into the slots with less difficulty.
MetroGTi is offline Find More Posts by MetroGTi
Old Jun 24, 2013, 10:59 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
The only reason I did it was for better torque on the rudder in the water, assuming the rudder was IN the water. The slot is out on the Wing 1 deck area so any water that comes through will just flow back off the plane and the deck isn't against the water surface anyway. I just assumed the larger rudder was to act as a water rudder. In the air the plane really just wants to crank and bank
Old Jun 24, 2013, 11:14 PM
MetroGTi is offline
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
I put the rudder pushrod below the wing to be sure that it would never get hit by the prop.
I enlarged the rudder to get better water handling. In the air doesn't help with turns, but it does help hold a knife edge.
Old Jun 25, 2013, 12:09 AM
MetroGTi is offline
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
And now we start on the floats...
The left and right floats are not identical. They should be mirror images of each other.
Be sure you build a left and right float ( not two lefts or two rights).
Discussion Flat Foamie Series from RA Cores coreman Foamies (Kits) 155 Jul 07, 2014 05:19 PM
Build Log The RA Cores EPP ME-109 coreman Foamies (Kits) 21 Jul 03, 2013 02:46 AM
Make a Good Flying Wing From Blu-Core?? Allora Foamies (Kits) 18 Jan 01, 2012 07:58 AM
Point me to a first foamie I can build from Blu Core, please! WarrrEagle! Foamies (Kits) 11 Nov 21, 2005 09:46 PM
