Old Jun 20, 2013, 03:50 AM
stevejet66 is offline
Find More Posts by stevejet66
United Kingdom, England, Wolverhampton
Joined Jul 2012
Video
The mijet kj66 trainer
Hi guys, Nearly finished my jet trainer, Homebuilt kj66 turbine, Only the wings to build, Airframe is light box alloy weight so far is 8bl 5oz. Check it out, turbine produces 17lb thrust. Any comments welcome, Good or bad.
KJ66 STAGE 4 RUN UP. (3 min 30 sec)
stevejet66 is offline Find More Posts by stevejet66
Old Jun 20, 2013, 06:08 AM
Boomerang1 is offline
Find More Posts by Boomerang1
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
How hot does your exhaust pipe get?
Reason for asking is that it's normal practice to have a gap between the end of the nozzle on your engine & the beginning of the pipe (typically about 30 mm but varies).
The gap allows the pipe to generate a venturi effect drawing in colder air to keep pipe temperature down.
Interesting construction technique, will the alloy frame be covered or is the model a 'Breezy'? - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Jun 20, 2013, 06:31 AM
Joined Jul 2012
Hi john, The jet pipe gets hot but not to the extent it throwing any major heat off it, to be fair you can put you hand very close to it and cant feel no heat as such, But! It is tempory just for testing as im ordering a proper one from wren this week.
Thanks for your interest good note you provided about the jet pipe.
Its going to be a half breezy, So it will have a front on and two sides at the front.
Cheers
steve.
Old Jun 20, 2013, 08:10 AM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, OH, Columbus
Joined Jul 2010
Don't forget the wheel brakes, but looks sweet.
mikes68charger is offline Find More Posts by mikes68charger
Old Jun 28, 2013, 01:12 PM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
is your fuel tank going to be that far forward of your wing?.. that will be a lot of change in cg during flight. move main tank back.. UAT forward.. the UAT(header) will stay full any way during flight.
rcshirt is offline Find More Posts by rcshirt
Old Jun 29, 2013, 02:49 AM
Joined Jul 2012
The tank is there for test runs only, Im mounting the tank on the cg in the centre of the airframe under the wings, UAT will go at the front.
Discussion Mijet II Sean Moloney Slope 22 Jul 13, 2013 10:07 AM
Discussion construyendo my turbina kj66 A G G Mexico 31 Aug 04, 2009 08:09 PM
Link Selling some KJ66 Parts (ebay) karlfoxman Jet Turbines 7 May 27, 2009 01:06 PM
Help! KJ66, Possible engine binding problem. karlfoxman Jet Turbines 3 May 22, 2008 07:54 AM
Wanted Mijet II Plans BOBMOX Aircraft - General - Miscellaneous (FS/W) 0 Feb 28, 2008 09:30 PM
