Old May 11, 2012, 08:37 PM
dockmanagement is offline
Find More Posts by dockmanagement
Joined May 2012
Motley crew blown prop
Ran my motley crew for first time this evening , within two minutes it started slowing down .. Both of the trailing edges of my plastic prop broke off !! I didn't hit anything or run to shallow ... I'm running 50 c lipos , could it be just to much torque ?? I have a brass coming anyways .. But kinda a short lived first run !! Was very impressive for first 90 seconds !! Anyone else have this happen ? What do you think ? Do I need to balance the new prop ? I don't race , just playing around .. Thanks
dockmanagement is offline Find More Posts by dockmanagement
Old May 11, 2012, 09:04 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Were you running 4s?
The cheapo props will throw blades and pieces at high speed, just balance and sharpen your new prop and you're good to go!!
scorpion1 is offline Find More Posts by scorpion1
Old May 11, 2012, 09:19 PM
Joined May 2012
Prop
Thanks sir , that's what I figured .. What balancer is everyone using ? Do you have to heat the prop ? How do you sharpen the edges ? I'm new at this ..thanks
Old May 11, 2012, 09:57 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
No heat, but wear a mask. Beryllium dust is REALLY bad for your health.
You'll want to balance and sharpen it.
wparsons is offline Find More Posts by wparsons
Old May 11, 2012, 10:43 PM
boaterguy is online now
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Get this balancer: http://www.offshoreelectrics.com/pro...prod=ose-80310
you can find it at a bunch of places. Sandpaper in many different grits and even a small file will really help you out. Google how to do it, there should be lots of articles (okay not how to do it, that would be interesting.. but you know what I mean)
boaterguy is online now Find More Posts by boaterguy
Old May 12, 2012, 09:46 AM
Joined May 2012
Prop
Thanks much for the help ! Will get one coming !
Old May 14, 2012, 06:03 PM
harbortime is offline
Find More Posts by harbortime
harbortime's Avatar
United States, WY, Moran
Joined Nov 2003
Anyone sell the blades balanced and sharpened?
harbortime is offline Find More Posts by harbortime
Old May 14, 2012, 06:15 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
offshoreelectrics sells some props b&s'd, there are also many people who will do it for you, look through the FS forum and if you can't find anything post a wanted ad.
Old May 15, 2012, 01:41 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
C rating didn't do it. They higher the C the better for the boat. Nothing bad can happen with a high c battery.
The stock plastic props like mentioned just break really easily. Something under the water could have dinged it and it failed its hard to tell. Metal props like mentioned are better, but a good easy and cost effective prop are the CF series props. The CF40, CF42 and CF45 are awesome cheap upgrades to the Motley Crew and are better then the stock props. They are still subject to breaking, but hold up a little better then the stocker. A metal prop is indeed the way to go, but a pre-sharpened and balance prop is pretty pricey and doing it yourself is time consuming and also a health hazard (beryllium cooper is really nasty stuff).
http://www.offshoreelectrics.com/pro...t=Carbon+Props
Diesel6401 is offline Find More Posts by Diesel6401
Old May 15, 2012, 01:53 PM
harbortime's Avatar
Joined Nov 2003
Great Info! What prop do you recommend for the best top end speed for a stock MC? The CF45?
Old May 15, 2012, 06:44 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Yes the CF45 would be the fastest out of listed series of CF props. It still wouldn't be as fast as a metal prop. The CF (and plastic for the matter) flex underload, so it's possible that even though you have a larger diameter cf prop a smaller diameter metal prop may produce better results. Example of this would be a x442 or a grim 42x55 will run faster and pull more amps then say a CF45 even though the CF prop is larger. Hopefully that makes some sense.
If ran with extreme caution and only used for 1 or 2 high speed passes a CF48 could be possibility. I mean EXTREME caution! The flex underload should make it tolerable for a very short period. When going to metal props everything changes.
Keep in mind that when you start playing around with props changing the deans plugs out for EC5 or 5.5mm bullets and changing the motor/esc 4mm bullets out for 5.5mm bullets is a must. They work fine for the small plastic stock motor, but when you start playing around with props the deans and small 4mm can't handle the increase in amps. This is a preventive must for any rtr boat that you wish to change the props with.
Old May 15, 2012, 07:34 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
I am going to change all my connectors to 5 or 6mm bullets. How do THESE or THESE look? Good prices too. I am running the GR 42-55 and the Traxxas connectors are getting too warm, hot even. But the wire is only 14g on the ESC, so that stinks.
What Octura prop is an equivalent to the GR 42-55? I would like to buy a pre balanced one from OSE, but they don't sell Grim Racer props already balanced.
stuball56 is offline Find More Posts by stuball56
Old May 15, 2012, 09:30 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
You can use regular 5.5mm bullets on your batteries as well, I do, but it is very VERY easy to dead short a battery with them. EC5's are a safer route on the batts. http://www.hobbyking.com/hobbyking/s...tor_Pair_.html
I would go with those and 5.5mm bullets for you motor/esc connections.
You'll need 3 pair for the 3 connection on the motor-to-esc: http://www.offshoreelectrics.com/pro...d=ose-55bullet
A octura x442 or x642 will do. More speed with the x642, slightly better runtime with the x442, pick your poison.
Snag this while your at it: http://www.offshoreelectrics.com/pro...se-cable-mcrew
* Aquacraft's flexcables are awfully, the prop shafts are normally wobbly and was a big issue with them snapping out of the box. Flexcables, collets, bullet connections and getting rid of the deans are normally the first things I do when I get a new rtr boat. The proboat cables however aren't too bad at all and I run them as is.
Here's mine:
Aquacraft Motley Crew (3 min 29 sec)
Old May 15, 2012, 09:57 PM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Thank you very much for that great information. Wow, that's good stuff. I did actualy install so far: Kintec Racing flex cable and strut bushing, nylon rudder bolt, I sharpened the rudder on the lead edge and the bottom, and I have a Kintec stuffing tube support bracket on order. I am now using an unbalanced 42-55 and it heats the stock wire and connectors up nicely. Too nicely.
Old May 16, 2012, 06:10 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Try not to run it unbalanced, you are doing damage to your motor and cable and will cause premature breaking.
I have a s/b tfl 42 prop I can sell you, it won't be as fast as an x442 though since it's got less blade area.
Wanted WTB miss geico hull or motley crew or mean machine or ul1 luisoque Boats (FS/W) 1 Feb 27, 2012 10:03 PM
Discussion Motley crew motor upgrade ? mavdriver Racing Boats - Electric 3 Jan 15, 2012 12:12 PM
Video Aquacraft Motley Crew Diesel6401 Dock Talk 3 Jan 03, 2012 07:54 PM
For Sale Motley Crew Boat parts floatn turd Boats (FS/W) 0 Dec 09, 2011 05:03 PM
