Old Dec 06, 2014, 09:31 PM
Joined Nov 2004
2/3 springer tug power
I'm building a 2/3 sized springer tug. I have a powertrain that includes a 380 sized motor and suitable prop. Will this be enough motor to move my foot long tug, or should I seek another option? I have everything in the junk box to get this little boat in the water, so it might be a try and adjust unless someone thinks it will be way to low powered to enjoy.
Thanks.
Chamkeeper is offline Find More Posts by Chamkeeper
Old Dec 07, 2014, 03:30 AM
Norwich, England
Joined Mar 2001
Try reading this thread on a 12" Springer. I think that I remember that a 385 was not enough but that a geared 400 worked fine. Remember that they wanted to push something rather than to just move the model.
http://www.rcgroups.com/forums/showthread.php?t=1616407
ChrisE is online now Find More Posts by ChrisE
Old Dec 07, 2014, 01:18 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Yes, It will be fine.
I have been running a Springer on 6v, with a 400 series with a 2.33:1 gear drive, and it
matches a stock 500 series motor. If your model is smaller, there should be no problem
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Dec 07, 2014, 03:29 PM
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
A geared Speed 400, would work better. More power, and, less load on the motor. Our boats run on 6v, as that allows for us to power everything, directly off of the main batteries. I have moved my 65 lb, 4' long deck barge with it. Here are some photo's.
CaptCB is offline Find More Posts by CaptCB
Old Dec 10, 2014, 05:29 PM
CaptCB's Avatar
Joined Aug 2011
Chamkeeper
Is there any other info you could use? They get small, and heavy, quick, when you start putting them together. Careful R&D though, will make for a great small pushboat. Mine has been running for over 2 years.
Old Dec 10, 2014, 06:37 PM
Senior Moment Member
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
CaptCB, what are the dimensions of your litte Springers, length, beam?
babblefish is offline Find More Posts by babblefish
Old Dec 11, 2014, 10:28 AM
CaptCB's Avatar
Joined Aug 2011
The fiberglass hull, for the 1/24 Truckable, is approximately:12" long x 5.5" wide x 3.25" deep. Here are some photo's of it next to a partially built, Microglass Springer. It really shows the size difference!
Old Dec 11, 2014, 06:41 PM
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
That's sweet! Is that a hull that can be purchased by mere mortals?
Old Dec 11, 2014, 06:54 PM
CaptCB's Avatar
Joined Aug 2011
It is part of a kit, but yes, we do sell the hull, and also the special hi-tech rudder, separately. PM me for price and info. CB
Sold Springer Tug boatfamily5 Boats (FS/W) 1 Dec 04, 2013 01:31 PM
Help! Like a Springer tug, but not a springer TamiyaCowboy Dock Talk 45 Oct 16, 2013 01:03 PM
Discussion Looking for help building a Springer stile gas powered tug. Cope Scale Boats 8 Mar 22, 2011 11:12 AM
Help! Looking for a River Tug or Springer Tug Tugboatjoe Scale Boats 14 Mar 31, 2008 03:24 PM
