Old Oct 08, 2014, 07:57 AM
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Originally Posted by demondriver View Post
I've heard that. . . But can't those chemicals hurt the balsa? I use warm water seems to work ok.
Works fantastic. No issues to date.
mike2663 is offline Find More Posts by mike2663
Old Oct 08, 2014, 10:26 AM
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
As I understand it, the ammonia affects the lignin, temporarily softening it, allowing the wood to become more flexible, in effect.
Once dry, all is well again.
Or at least that's close to what I recall reading about it...
James
Deuce is offline Find More Posts by Deuce
Old Oct 10, 2014, 08:19 AM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Why the splice plates? Seems unnecessary with a good glue joint.
Old Oct 10, 2014, 09:18 AM
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Interesting question Mike... Probably not vital when joining sheet before fitting onto the model - though I'm not sure I would trust a whippy thing two sheets long not to get away from me and break apart at the joint.
I use them because my choice is to fit one sheet at a time so as lengths don't get too unmanageable. I then add the splice plates to assist in getting the (by then curved) sheet ends in line.
The question did not therefore occur to me - maybe Jay has a different take on it...
Robin
eye4wings is offline Find More Posts by eye4wings
Old Oct 15, 2014, 08:22 PM
Joined Feb 2012
Ok gang since I had a LOT of spare time at my latest chemo treatment I had time to ponder how to put the skin on.. Seeing as there is that nice box frame on the inside that would make a dandy cut ref.. The sides will follow the line on the inside of the frames.. which allows the top and bottom to join at a flat spot instead of on the curve. Now since this baby is a tad wide in the beam, it behoved me to see just how fat she is... did I just say that?? so on with the paper to see how much to add to the bottom sheet..
jt
jpt62 is offline Find More Posts by jpt62
Old Oct 15, 2014, 09:26 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Good idea jt, that should work well.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: OV-10A Bronco from Palmer Plans
Old Oct 16, 2014, 12:20 AM
Joined Feb 2012
Yup worked great John. It is a tad over 10.5" at the widest point.. Ok so how much do I need to fill the gap and where will it be? Easy to find out.. Main sheet is 6" so 3" from center is marked and what is left is the dimension.. Out near the end the bottom sheet will get trimmed to keep things straight. The side sheets get their bottom cuts straight from the plans
jt
Old Oct 19, 2014, 02:40 AM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Solid Progress on your B-24 Build JT!
demondriver is offline Find More Posts by demondriver
Old Oct 19, 2014, 08:45 AM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
This has got me thinking.
http://leisurercmodels.com/jack-staf...dels-kits.html
Old Oct 22, 2014, 10:36 PM
Joined Feb 2012
Bottom sheet in the process of getting formed... Getting a tad aromatic out in the shop...
Old Oct 23, 2014, 07:59 AM
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Boy, that hammers home how big the fuse is, doesn't it?
Nice work Jay,
Regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old Oct 23, 2014, 08:17 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
And buy some stock in a masking tape company too jt.
Good to see they sheeting started.
J
Old Oct 23, 2014, 07:46 PM
Joined Feb 2012
Letting things air out now...
jt
For Sale Vintage Consolidated Models " Hustler " kit NIB tchant Aircraft - Sailplanes (FS/W) 0 Jan 13, 2013 12:20 AM
Sold Consolidated B-24D Liberator jacktrotter Non R/C Items (FS/W) 2 Sep 25, 2012 04:32 PM
Sold Consolidated B-24D Liberator jacktrotter Aircraft - Fuel - Airplanes (FS/W) 1 Sep 25, 2012 02:15 AM
Mil Mi-24D Hind - Scale body for Piccolo/Hummingbird etc. MRP Scale Helicopters 2 Nov 17, 2004 07:31 AM
