Space Coast
Joined Oct 2000
Like Rodney says - here's my soldering iron "hot knife". It's an Exacto blade silver soldered to a brass screw that threads into the soldering iron. It has many many uses.
http://www.rcgroups.com/forums/showp...6&postcount=21 |
Thanks for the idea, I have a purpose made hot knife, I will try that next - but first a quick update of a test done over the last two nights.
I glued some scrap 1/8 ply with 5min epoxy and left it overnight. One joint i added some CA 'un-cure' and it instantly made the joint go 'crystally' and the upright piece fell over by itself. The second joint I brushed on some polyester resin as suggested and it took much longer but it softened the joint to the point where I gave it a gently 'poke' and the upright piece fell over. However it's just a gooey mess now. I guess a solvent isn't a good idea because it would also penetrate the ply and weaken the glued layers of ply? I will set up another test and try my hot knife.
Space Coast
Joined Oct 2000
I'm wondering about that 5 min epoxy. Is it really curing? If you repeat the test and then physically break the joint, how much pressure did it take? Did the wood break or did the glue joint fail? Fully cured epoxy is pretty solvent resistant. Here's some info on the subject. It may just be that the 5min stuff is pretty poor epoxy strength wise. http://www.epotek.com/SSCDocs/techti...ed%20Epoxy.pdf |
Space Coast
Joined Oct 2000
| Thread Tools | |
| Help! Removing epoxy from the inside sleve of the pheonix 2000 glider. | David97 | The Builders Workshop | 4 | Mar 14, 2013 08:46 PM |
| Help! best uncured 5 min epoxy remover? debonder? | grfcon | The Builders Workshop | 6 | Feb 04, 2013 02:57 PM |
| Mini-HowTo Micro Heli CNC Head Ball Joint loosening | RChamberlain | Micro Helis | 0 | Apr 29, 2007 10:28 AM |
| Question Epoxy to Epoxy joint? | lwndart | Beginner Training Area (Aircraft-Electric) | 3 | Mar 07, 2006 07:21 AM |
| Graupner U-Joint Loosening Problem | X190 | Racing Boats - Electric | 3 | Nov 18, 2005 08:41 PM |
