Old Jun 06, 2004, 08:51 PM
Broomfield Jeffco, Colorado, United States
Joined Jun 2004
Direct drive Props for Pico F
My name is Pat and I live in Broomfield CO (suburb of Denver) and I have just started flying a Pico F with the 280 direct drive motor. It uses the press on style of prop, so no threads. I'm having trouble with the prop flying off after a few minutes of flight time. Is there a secret to keeping these props on after the motor warms up? Any help would be great!!! Thanks
67lemans is offline Find More Posts by 67lemans
Old Jun 06, 2004, 09:27 PM
know it all
Miami, Fl
Joined Nov 2003
put a bit of locktite on the treads..
Herm
hermperez is offline Find More Posts by hermperez
Old Jun 07, 2004, 10:39 AM
Balsa!!!
Singapore
Joined Sep 2003
I had that setup too... I find it VERY underpowered.
What I did was to use the rubber spinner with the smallest hole. Just press onto it hard... it won't fall off. Failing that use some glue...
csisfun is offline Find More Posts by csisfun
Old Jun 07, 2004, 11:42 AM
Joined Jun 2004
Yah the prop it came with wouldn't even get the plane off the ground so I moved to a 7060. It works alot better but I havn't had enough time in the air to find out how long the battery will last.Sounds easy enough.
Pat
Old Jun 07, 2004, 12:08 PM
Balsa!!!
Singapore
Joined Sep 2003
7060 prop seems overpropped to me... the motor might blow fast.
You might want to get the EPS100 or IPS. They work much better. I used to have that plane, albiet the stick version.
Discussion Free Direct drive props for 4,6,7mm motors Bob Blackburn Scratchbuilt Indoor and Micro Models 10 Dec 16, 2006 06:33 PM
Discussion MAX rpm for direct drive props Fire42 High Performance 1 Aug 06, 2006 07:38 PM
FS: Direct drive props & prop adapters for Speed 400/480 and small brushless motors kyril Aircraft - Electric - Airplanes (FS/W) 1 Apr 28, 2004 11:28 PM
GWS rubber inner adpters for GWS direct drive props GWS4CEO Parkflyers 1 Nov 14, 2001 09:35 AM
folding props for pico stiks Skysailor Parkflyers 3 Sep 07, 2001 09:45 PM
