Old Sep 07, 2001, 05:52 PM
Indy, IN
Joined Feb 2001
e-gull
are the e-gull and the firefly the same thing?
newton is offline Find More Posts by newton
Old Sep 07, 2001, 07:38 PM
Walled Lake, MI, USA
Joined Feb 2000
There must be 5 or 6 slightly different versions of this same basic package marketed by different companies. There is a comparison chart of 3 of them at:
http://www.toytx.com/egullparkflyer.html#Compare
Dave Hederich is offline Find More Posts by Dave Hederich
Old Sep 07, 2001, 08:38 PM
Bleriot's Avatar
Joined May 2000
The E-gull has no up/turn mix and is more likely to spiral, motor not same as Firebird. 4" prop instead of 5" Firebird has better duration for getting into more trouble. Right Dave!! Best Regards
Bleriot is offline Find More Posts by Bleriot
Old Sep 07, 2001, 10:41 PM
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
I'm partial to firebird xl. Got over 125 flights on it. Uses 2 channels, one for throttle and one for turning. I'm designing a new vee tail for it. Much bigger with a larger control surface. The XL version uses a mabuchi 380 motor and the servo and esc are on a pcb board along with the receiver.
I run the stock 6 cell 900 mah nimh battery and I'm getting 18 minutes of flight time.
This plane had mucho crashes when I first started flying in May of this year. My main wing is fully taped from the crease of each dihedral. Protects against prop crunch of the back edge of the wing. Extremely easy to fly because it flies slow. I currently fly a T-52 and a sky scooter pro but I will still bring the firebird out for relaxation.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Wanted- E-gull, Firebird Xl Etc greatplanes Aircraft - Electric - Airplanes (FS/W) 0 Feb 28, 2002 04:38 PM
FS: E-Gull Transmitter sgil2001 Aircraft - Electric - Airplanes (FS/W) 0 Dec 21, 2001 09:47 PM
E-Gull or Firebird mt_100 Parkflyers 1 Nov 12, 2001 04:49 PM
E-Gull Parkflyer Fly_joy Parkflyers 3 May 22, 2001 10:33 PM
e-gull vs. firebird rktung Beginner Training Area (Aircraft-Electric) 4 Apr 24, 2001 10:42 PM
