Old May 19, 2014, 03:11 PM
nr1
Joined Feb 2012
Multiplex Razzor: which brushless motor
Hello guys,
i got a Multiplex Razzor and need a new brushless motor for it. The stock one is a 'Permax BL-O 2316-1400' with following data:
Type: BL-O 2316-1400
# 33 3104
RPM / V: 1400
Cell count
NiXX / LiPo:
6 - 9 / 2S - 3S
Optimum working range: 10 A 15 A
Max. current for 15 sec.: 20 A
Shaft : 3,0 mm
Diameter: 23 mm
Length: 29 mm
Weight: 43 g
Max. output: 120 W
Max. rotational speed: 20.000 Umin-1
Max. case temperature: 65o C
Mounting: 16 mm / 4 x M3
The problem seems to be the max. diameter of 23mm and ~120W of max. output. Does anyone know something similar from Hobbyking or any other supplier?
nr1 is offline Find More Posts by nr1
Old May 30, 2014, 12:47 PM
nr1
Joined Feb 2012
No one?
The stock motor is delivered with 7x6 Prop.
I know found this series of brushless motors available on ebay:
http://www.dys.hk/ProductShow.asp?ID=27
Guess those should be ok / equal to stock?
Which one to prefer, the 1600 or 2000kv?
Old Jun 01, 2014, 09:59 AM
nr1
Joined Feb 2012
Really no one?
Old Jun 21, 2014, 03:32 PM
Joined Jun 2014
I smashed the motor shaft on its first flight and found them nearly impossible to get hold of. Rather than attempt to fit a motor into the fuselage I bolted an Emax to the front.
JohnWakefield is offline Find More Posts by JohnWakefield
Old Jun 22, 2014, 04:10 PM
nr1
Joined Feb 2012
Hello,
finally i bought the motor i linked above. Was already installed, however i didn't fly the Razzor yet. Can you post photos of your Emax in place?
Old Jul 17, 2014, 07:43 AM
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Not a very popular plane, it seems.
Wing-span is offline Find More Posts by Wing-span
Old Nov 20, 2014, 02:31 AM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
But.... I bought one. And now too I need a new motor.
Old Nov 20, 2014, 11:42 AM
nr1
Joined Feb 2012
You can try the same motor (I took the 2225/15 - 1600kv) as i linked above. I already installed it into my Razzor, only needed to do some slight modification (some filing) on the plastic motor mount. However i didn't maiden my Razzor yet, as i decided to first practice flying with a more or less similar UMX plane.
Old Dec 18, 2014, 06:28 AM
Australia, VIC, Melbourne
Joined Nov 2014
I bolted one of thesein from hobbyking and it works fine:
http://www.hobbyking.com/hobbyking/s...er_2050kv.html
I had to reverse the shaft so that i could bolt the motor in.
Fits perfect - probably too much power.. gets very hard to see very quickly...
antstar is online now Find More Posts by antstar
Sold Multiplex Razzor edf nut Aircraft - Electric - Airplanes (FS/W) 0 Mar 30, 2014 09:56 PM
Discussion Brushless Motor Help (which kv) PocketsPB Power Systems 13 Nov 21, 2013 04:57 PM
Sold Multiplex 480/4G geared brushless motor Lammergier Aircraft - Electric - Power Systems (FS/W) 1 Oct 09, 2013 03:17 AM
Sold Multiplex Razzor - $80 - LPU TuneUp Aircraft - Electric - Airplanes (FS/W) 0 Oct 04, 2013 11:54 AM
Discussion Multiplex Twinstar Brushless Motors - Which Ones? levaz Power Systems 3 Dec 26, 2011 05:17 PM
