Old May 31, 2011, 07:23 PM
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Question
Lipo's of different AH all in parallel...
Lets say I have a center 5000mah, and two 2200 mah's lipos as "wing tanks" all wired together in parallel....
The load should drag all down equally shouldent it??
SilentHunter is offline Find More Posts by SilentHunter
Old May 31, 2011, 08:22 PM
So. Cal.
No problem at all running different capacities in parallel provided they're all the same cell count. Just be sure that they're at the same charge state prior to connecting and derate to the lowest capable pack (e.g. - two 40C packs in parallel with a 30C pack should be treated as a 30C pack).
Also, be careful with long battery to ESC leads if you plan to have 'wing tanks' as long battery leads can wreak havoc on your ESC. Most ESC manufacturers recommend 12" maximum battery to ESC leads.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old May 31, 2011, 08:28 PM
Joined Aug 2003
Yeah what I figured Mark, thanks. i have mig-17 and zero room for any more battery in the fuse cause of the ducting, but i have 2 drop tanks Thinking of 2x2200 mah 3s wired in series then connected to the main lead which is 6s. So each tank would have a 2200 3s.
You know i tried to contact Hobbywing about long battery-esc wires, and got nothing from them. I have an airliner that runs about 4.5 feet from batts to esc's. Seems to run perfectly fine but... maybe should add capacitors??
Im not sure what the deal with that is exactly.
Old May 31, 2011, 08:53 PM
Joined Aug 2003
Just read through this on tha capacitors: http://www.rcgroups.com/forums/showthread.php?t=952523
so i need quite a few. another subject though.
Old May 31, 2011, 09:11 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
<<<<<<<<<<<<edit>>>>>>>>>>>>>>
Just realized that the higher capacity battery would hold the voltage up in the depleted pack/packs so there wont be any low voltage damage on the smaller capacity packs. Is that right?
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old May 31, 2011, 10:46 PM
So. Cal.
Bingo.
Mark
Help! ESCs in parallel running at different speeds. lucidshift Multirotor Talk 18 Mar 21, 2011 11:52 PM
Discussion Wiring ESC's and BEC's in Parallel? dashunde Power Systems 3 Mar 18, 2011 10:49 AM
Discussion What's a good all-in-one lipo battery analyzer? flynfish67 Batteries and Chargers 2 Mar 18, 2011 06:28 AM
Discussion Safely connecting different voltages in parallel for LiPo's ChickenStick Batteries and Chargers 3 Dec 23, 2005 01:43 PM
different lipo's in parallel? TMASTER Batteries and Chargers 16 Sep 14, 2005 08:01 PM
