Old Dec 11, 2014, 08:00 PM
United States, PA, Lancaster
Joined Mar 2014
Paint is awesome kwahn....hows the belly?
darkmanvr6 is offline Find More Posts by darkmanvr6
Old Dec 12, 2014, 12:16 AM
United States, TX, Houston
Joined Mar 2014
Originally Posted by darkmanvr6 View Post
Ok 2200 4s is here, ready to maiden. Ive read so much on cg and so many dif opinions. If i just want to take it out for a conservative spin no craziness like i try with the Habu 2 what measurement do u guys recommend. Im leaning towards 75mm??? Any thoughts? Thanks all!
My 4s flys between 60 and 70 with no problems.
kthadlee53 is offline Find More Posts by kthadlee53
Old Dec 12, 2014, 11:15 AM
Germany
Joined Jul 2010
Thanks, I guess anything is an improvement over what it looks like stock.
The belly is dark blue because I ran out of orange and that's what I had left.
Kwahn is offline Find More Posts by Kwahn
Old Dec 12, 2014, 10:43 PM
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
Originally Posted by Kwahn View Post
I couldn't bear to look at the original mk2 color scheme any more so I did this. I hope I can stand that view for a little longer. The stock paint and decals come off relatively easy with duct tape and gently applied heat, stripping, waterbased PU painting with a paintbrush and finally spraying with some rattle can leftovers still took several hours.
I tried to strip the paint off of one of my fuselages...got most off. but left a lot a crap inbetween all the small foam cell cracks.
I like your paint scheme !!
KCinNC is offline Find More Posts by KCinNC
Old Dec 13, 2014, 10:20 AM
Germany
Joined Jul 2010
Yes, stripping the paint isn't a lot of fun. You need really sticky tape and a heat gun. Clean the surface, cover it in tape and then heat it gently while rubbing the tape with your fingers for better adhesion, as long as you don't burn your fingers the foam won't pop any bubbles. Give it a minute to cool down and remove the tape with hopefully all of the paint. I found everything came off well on the Stinger 64 except for the bottom of the wing which took more work and some sanding. You still need to sand some and wipe down with alcohol for the new paint to stick. If I did it again I would invest in some suitable epp friendly spray paint and skip the pu paint.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1355 Today 09:12 AM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 10:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 03:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 08:52 AM
