Old Dec 09, 2014, 11:00 AM
Wild & Crazy
United States, AR, Little Rock
Joined Apr 2013
I have the 64mm Version of the Hobby King T-45, and am using this EDF unit.
http://www.epf.com.tw/goods.php?id=125
I will be running a Nanotech 5s 2700mah 65c, with a ZTW 100Amp ESC, the kit is almost finished and i have put the EDF thru some bench tests getting around 1500g thrust
Does anyone out there have a setup like mine and what kind of performance will i be getting. i was going to use 4s because i have plenty of 4s lipos in my hanger, but then i saw that this fan unit was able to use 5s, so here i am waiting for HobbyKing to deliver the Lipo and a Canopy latch, and some odds and ends
any response thanked
Sovrin is offline Find More Posts by Sovrin
Old Dec 09, 2014, 11:05 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I assume the 1500gr thrust is UN-installed EDF unit before fitting to airframe ?
I would think that one factor you might encounter is air feed .. some who have pushed these models and others similar to really high numbers encounter starvation of air to the fan ...
My fingers crossed that you don't.
Nigel
solentlife is offline Find More Posts by solentlife
Old Dec 09, 2014, 04:51 PM
Wild & Crazy
Joined Apr 2013
Nigel
Ya am probably going to cut a cheater hole in the wing befor the edf unit, like so many have here in this thread
Old Dec 10, 2014, 09:57 AM
90mm F-16
Tartago's Avatar
Joined Apr 2006
So ? Doesn't change fact it is a SAPAC based model.....
Nigel
Sapac is long dead. Hail the King!
Tartago is online now Find More Posts by Tartago
Old Dec 10, 2014, 09:59 AM
90mm F-16
Tartago's Avatar
Joined Apr 2006
I used that setup and on 5s she had unlimited vertical.
I'm planning another kit with 6s.
Old Dec 10, 2014, 12:49 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Actually it is a Global Fly model. SAPAC was the American distributor/rep.
fredmdbud is online now Find More Posts by fredmdbud
Old Dec 10, 2014, 09:56 PM
90mm F-16
Tartago's Avatar
Joined Apr 2006
There are just a few companies doing the moulding and injection of eps or EPO airframes on order.
The brand owner just have to order a minimum 500 pieces and then paint and add the electronics of choice.
Old Dec 11, 2014, 02:38 AM
solentlife's Avatar
Joined Jan 2010
Unlimited vertical is perfectly possible on 4S ... the difficulty comes when people start mucking about with blade numbers to achieve the 'whooosh' sound ...
Stick with stock fan and a good 4S and a reasonable 4300 or more kv motor and she will punch holes in the clouds. My T45 similar weight, but slightly smaller span has 4300 + 5 blader + 4S 2700 and she will go out of sight vertical.
Here when she was just being set-up ....
T45 64mm 4S 2700 21-09-12 (5 min 38 sec)
Text says 0.9 - 1 T/W ratio and 120 - 130kph ... in fact when I altered CoG .. removed a few bits in tail pipe ... she recorded 1.1 to 1 T/W ratio and speed average of 140kph. I accept this is not the 'SAPAC / HK' T45 .. but she carries the same weight and drag penalties. In fact where the model is a tny bit smaller - the intakes and ducting is likely slightly restricted compared to SAPAC / HK version.
If she doesn't go vertical - then somethings wrong.
Nigel
Old Dec 11, 2014, 07:25 AM
90mm F-16
Tartago's Avatar
Joined Apr 2006
I don't know the stock setup since I bought the kit.
I tried the 4s setup with a one of the Freewing's Su-34 fans and it was not good enough.
With the Mercury on 5s it was far better.
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1022 Dec 11, 2014 06:19 AM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 03:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 05, 2010 12:37 AM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 11:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 05:44 PM
