Old Mar 27, 2015, 07:06 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
stabilizer on 3d planes
i have been flying 3d for a while, and recently considered using a stabilizer (those with gyros) to see if my planes could be easier to fly when attempting hanging vertical.
there is a thread on them: http://www.rcgroups.com/forums/showthread.php?t=2164243 and at the end i posted a question regarding the issue.
i got an answer that sounds encouraging (post 2502):
he said:
I use a gyro in this Pogo that does fly vertical, sort of a poor mans 3D
It's set up conventionally, as when you do go to level flight, the gyro is operating properly. As far as vertical goes, the gyro doesn't know that the plane is vertical. The surfaces operate in the same manner, even at zero speed. The gyro makes it much more comfortable to fly. It flies in level flight much like a trainer plane.
Gord.
so, besides him, has anybody tried them for 3d?
phil alvirez is offline Find More Posts by phil alvirez
Old Mar 27, 2015, 07:52 AM
ahicks is offline
Find More Posts by ahicks
United States, FL, Citrus Springs
Joined Aug 2008
I use the Orange 3 axis, and for what they cost, would recommend them without hesitation on anything on the 1m (39") or bigger wingspan planes where the weight is easily written off/offset with increased performance.
I find flying in the wind is much easier, as well as high alpha and knife edge. It's certainly not like you're on auto pilot or anything. You're darn sure still flying the plane, but it's like you just have more time to think? Found that hover results not that big a deal. I suppose it may be possible to tweak the gains for enhanced hover performance, but that's not been necessary for my flying style.
They're available as a stand alone or with built in (DSM2) receiver. Link to stand alone:
http://www.hobbyking.com/hobbyking/s...elta_AUX_.html
ahicks is offline Find More Posts by ahicks
Old Mar 28, 2015, 03:24 PM
poppopfox is online now
Find More Posts by poppopfox
poppopfox's Avatar
United States, PA, Reading
Joined Jan 2010
Lemons
I have a 39" epp plane that I was about to give up on because of wing rock while attempting harriers. Installed a Lemon 7 channel stabilized receiver, with the gains set on the low side, and now I can move up on the learning curve, wing rock is gone. To be honest, I also installed some small vg,s on the wing so that may have helped as well. Others have remarked that a stabilizer (gyro) makes the smaller planes fly bigger (smoother, like with a higher wing loading). +1 on that and I'm glad I gave it a try.
poppopfox is online now Find More Posts by poppopfox
Discussion 3-Axis Flight Stabilizer + 3D plane =?? big_poppa4904 3D Flying 4 Oct 06, 2014 05:11 PM
Discussion The Guardian 2D/3D Stabilizer and elevon planes AJay Scratch Radios 1 Apr 17, 2014 09:42 PM
For Sale Best and final sale on lot of Extreme flight 3d planes! Bnh105 Aircraft - Electric - Airplanes (FS/W) 0 Sep 29, 2013 03:05 PM
For Sale Price drop on 3d planes Bnh105 Aircraft - Electric - Airplanes (FS/W) 0 Sep 25, 2013 07:11 PM
Discussion RC Plane stabilization using KDS FLymentor 3d (for helis) thundead Electric Plane Talk 3 Jul 09, 2011 12:16 PM
