Old Nov 14, 2014, 05:52 AM
John 3:16
Joined Jul 2014
Gws pico tiger moth motor mount help
Hi.
I glued the fuselage together without doing anything with the stick mount for the motor.
How should it lay?
when i test fit it, there seems a lot of movement.
Should i just hold the stick ( when i am looking FACING the front of the plane, head on ) down and right to get the right offset?
Dean
CalvaryStudy is offline Find More Posts by CalvaryStudy
Old Nov 14, 2014, 05:55 AM
John 3:16
Joined Jul 2014
Also, do the wings just stay on?
Can i put ailerons on it?
Old Nov 17, 2014, 04:42 AM
Taipei, Taiwan
Joined Oct 2005
Hi Dean,
Rudder+dihedral works great on this Pico TM, aileron could not work well on it unless you glue depron sheets to the bottoms of its wings.
And 1.5 - 2 degrees down thrust and 1 - 1.5 degrees right thrust are required on this PTM, also make sure that you look at it from its tail to its nose when telling the right thrust.
You'd have to work on it more if you prefer having both wings removable.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Nov 18, 2014, 11:51 PM
John 3:16
Joined Jul 2014
Fantastic. Thanks, Chen.
Thats what i needed to know, which way to look at the plane when putting the down and right.
I have no idea how do to the degrees, what would be the amount in mm.?
Its a smaller plane than i though, so the wings can just stay on i guess.
You have been VERY helpful, thank you.
I wish we had more GWS planes in New Zealand.
Would LOVE a stealth/b2!
Old Nov 19, 2014, 11:04 PM
Taipei, Taiwan
Joined Oct 2005
Hi Dean,
The wood stick is 8mm wide, so draw a center line on it first. I did tell my buddies to apply 1.0 mm for both thrusts when hating to tell the degrees accurately. And be sure to use the trims if the thrusts are not enough, as the motor and prop used might make it differently.
Hope these would be helpful.
Chen
p.s. Please be reminded to view the included manual first. It tells you more.
Old Nov 20, 2014, 08:03 PM
John 3:16
Joined Jul 2014
thanks.
I already glued the mount in and just held it as far down and right as i could and it seems ok.
Dean
Originally Posted by GWS CHEN View Post
Hi Dean,
Chen
Old Nov 20, 2014, 10:06 PM
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
Be sure to put flying wires on it out of dental floss or Dacron fishing line. The wings bend easily without it.
Mel Duval is offline Find More Posts by Mel Duval
Sold NIB GWS Tiger Moth 3D W/350 motor Broken wing 31 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Oct 09, 2014 06:11 PM
Wanted GWS Pico Tiger Moth tqpham Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jul 31, 2014 06:50 AM
Discussion GWS pico tiger moth eilerons upgrade..help! guyg Foamies (Kits) 0 May 15, 2008 05:44 AM
Discussion Help me build GWS pico tiger moth or bigger 400 tiger moth wrangler Beginner Training Area (Aircraft-Electric) 2 Dec 07, 2006 12:28 AM
