Old Apr 15, 2014, 05:02 AM
Joined Apr 2014
First quadcopter
Hey there,
I would like to build my first quad copter with my GoPro on it. After past long time looking at the different parts i finally make a chose. But before purchasing i would like some advice from this forum.
I m not sure all things will work together (motor enough powerful to lift the quad, etc) or if i forget important things
Here is my buy list:
1x Turnigy Integrated PCB Mini-Quad 345mm (KIT) http://hobbyking.com/hobbyking/store...45mm_KIT_.html
5x NTM Prop Drive Series 28-26A 1200kv / 286w http://www.hobbyking.com/hobbyking/s...00kv_250w.html
4x NTM Prop Drive 28 Series Accessory Pack
4x NTM 28 Carbon Fibre Motor Mount
5x Turnigy Multistar 30 Amp Multi-rotor Brushless ESC 2-4S http://www.hobbyking.com/hobbyking/s..._ESC_2_4S.html
1x 8x4.5 SF Props 4pc Standard Rotation (Yellow) http://hobbyking.com/hobbyking/store...n_Yellow_.html
1x 8x4.5 SF Props 4pc R/H Rotation (Yellow) http://hobbyking.com/hobbyking/store...n_Yellow_.html
1x IMAX B6-AC Charger/Discharger 1-6 Cells (GENUINE) http://hobbyking.com/hobbyking/store/__6478__IMAX_B6_AC_Charger_Discharger_1_6_Cells_GE NUINE_.html
1x HKPilot Mega V2.5 Flight Controller USB/GYRO/ACC/MAG/BARO
http://hobbyking.com/hobbyking/store...ontroller.html
Turnigy 4000mAh 4S 30C Lipo Packhttp://hobbyking.com/hobbyking/store...idproduct=9511
Thanks in advance,
Regards, Marques
Marques is offline Find More Posts by Marques
Old Apr 15, 2014, 07:49 PM
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
Hi .
I would choose a heavier frame than the mini . This is more for fun flying than for video. For a first build try an H quad to carry a Go Pro . It is simple to build and fun to fly, or any of the other quads or tri's that are designed to carry a Go Pro.
Gordon
reelflyt is offline Find More Posts by reelflyt
Question Very first RC quadcopter Pilgrim_ Multirotor Talk 3 Oct 19, 2013 04:42 AM
Discussion First quadcopter project. eadrom Scratchbuilt Multirotors 0 Oct 14, 2013 04:28 AM
Discussion The First paper quadcopter! bluesteel212 Multirotor Talk 2 Oct 02, 2013 02:53 PM
Help! Need help for my first Quadcopter amila_neranjan Multirotor Talk 0 Sep 19, 2013 03:34 AM
