Old Nov 15, 2003, 01:56 PM
CooLJ92's Avatar
Fresno, CA
Joined May 2002
Question
GWS P51 Battery Question
My friend recently handed me two packs of 9.6v 1200mAh NiMh battery packs. The batteries on are 8 AA batteries. Will you recommend flying my GWS P51 with these packs or will it be too heavy?
Currently I have the stock motor (350) and stock "C" gear on her.
Any recommendation will be appreciated.
jj
CooLJ92 is offline Find More Posts by CooLJ92
Old Nov 15, 2003, 04:54 PM
Melbourne Australia
Joined May 2003
hmm...she may be a bit heavy. And i'm not sure if it will even fit in the battery bay.
The "traditional" pack for this bird is the 7 or 8 cell AAA packs (700-1000mah nimh's) 2s and 3s lithium packs are also an excellent power pack.
it "may" work, but I don't think it will fly very well. (in my opinion anyway). As a rule, lighter is better.
Good luck
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Nov 15, 2003, 08:28 PM
Joined Feb 2002
I'm flying mine with the 350 on 8.4/1000 NiMH 2/3 A & 8.4/650 NiCD AA or 2/3 AA (I'm not sure which) and it flies well on both.
DEWorley is offline Find More Posts by DEWorley
Joined Feb 2002
PS
That's with the 9x7 prop. I tried a 10x7 first but liked the 9x7 better.
Old Nov 15, 2003, 10:42 PM
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
I fly with a AA 7 cell 600 pack. It flies good, with a EPS 300 though. The cells can't weigh that much more, can they?
larsy87 is offline Find More Posts by larsy87
Old Nov 16, 2003, 03:45 PM
CooLJ92's Avatar
Fresno, CA
Joined May 2002
The battery pack fits in the battery tray perfectly. You are right, the P51 is heavier.
Thanks for your comments. This will definately save me from crashing her.
I currenlty use a 2s1p Etech 1200 with a 9X7 prop. I will be upgrading to a APC 10X7 parkflier prop. Many individuals are using this and they state it makes a world of a difference.
Thanks for the comments.
p.s. I tried the pack with my Estarter, but she was sort of slow in the air. Had to modify the compartment a bit.
jj
Old Nov 16, 2003, 04:24 PM
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
make sure you do get the slowfly apc props, I ran a 10x7 APC TE, and it sucked... it would unload way too early... only pulled about 7.5 amps (great 20 min flights, but wouldn't climb worth a darn).
the gws 1080 flew better than the rest, but my pack would get pretty hot (kokam 1500 2s) and the 9070 gave the best speed, and a little less climb than the 1080... but worked GREAT.
Phreakish is offline Find More Posts by Phreakish
Old Nov 16, 2003, 06:43 PM
TOPEKA KS
Joined May 2002
I am currently using a 350 motor and c GB....using AAA 9.6 v sanyo 730 mah nimh flat pack...getting up to 9 min of nice robust flying with the p51...but when i use the Kan 650 9.6 v 8 cells it flys out of my hand like a rocket..and get up wards to 8 min time using throttle managment....using 9X7 prop... i do not use any weight up front ...it has perfect CG at the manuals recommendations...this is a real flying beauty....hope you really enjoy your GWS P51...
Al in Kansas
AL TYLER is offline Find More Posts by AL TYLER
GWS Lipo Battery question FDC GWS (Grand Wing Servo) 1 Sep 25, 2004 01:23 AM
GWS P51 battery Chippie Foamies (Kits) 0 Dec 21, 2003 03:54 PM
GWS A-10 Battery Question memscoot Parkflyers 2 Mar 27, 2003 07:53 PM
GWS P51 building question. mrebman Parkflyers 5 Feb 16, 2003 10:31 PM
GWS beaver battery question pc_pilot Parkflyers 9 Oct 22, 2002 11:48 AM
