I've noticed that some EZ folks have issues with their control rods not being smooth to the rudder. I think that the control rods provided with the EZ are some of the best I've seen with a stock plane. Even the Terry Graupner only comes with a wire and one tube. The EZ is a "triple" control rod system; an inner wire, inner sheath, and outer sheath. Holly smokes! The wire can move in the inner sheath and the inner sheath can move in the outer sheath for a super smooth operation. If this system is binding or sticking a good look needs to be taken on how it was installed.
Here is a picture. The rudder control rod goes straight back. I put a "Z" bend in the wire in front of the horn. This eliminates the down pressure on the horn which could lead to binding and twist. The bend won't flex the wire is very stiff. Also note that I used a micro park flyer quick connect on the horn. I broke the one that came with the EZ by over tightening. The connect I replaced it with is smaller, lighter, and you only need a screw driver to make an adjustment not the allen key that you can find when you arrive at the flying field. Don't forget to put loctite on the screws so they don't vibrate loose. Added 4/2/06: I use loctite or Permatex Threadlocker blue (medium strength) on the EZ rudder/elevator connectors. Here is a picture of a Du-Bro Mini E/Z Connector. Putting loctite on is a good extra measure. Fact: Screws can vibrate loose in time, especially without a lock washer. Keep in mind that these screw types of connectors are for "slow flying aircraft". Many clubs will not let you fly at their fields with these sscrew post types E/Z connectors; "Z" bends and clevice connectors only please. ![]() I have included other types of horn connectors used on faster flying and more acrobatic models. Happy flying. ![]() Sarge
Get Stamps with your favorite AP photo on them.
This is a fantastic site to visit to get "real" USPS stamps made of your favorite AP photo. Come to think of it, I just may get some stamps made of my favorite EZ star build photo in the thread.
![]() http://www.pictureitpostage.com/ |
Joined Mar 2004
For the Canucks or collectors... http://www.canadapost.ca/personal/co...?stamp=postage
Here is a picture of my Easy Star cockpit. You can see the nice new Hitec "555" and E-flite 20 amp esc. What a snap to change out the 40, Three gold connectors and that's it.
Update: 11/17/06 Receivers that have worked for me. 1. Hitec 555 - Been around for awhile - very reliable, glitch free, long range 2. Berg 5 Very reliable, long range http://www.rc-direct.com/Berg_5_micro.htm 3. FMA M5-v2 - Very small, durable, works as well as a Hitec 555. Has fail safe technology. http://www.fmadirect.com/Detail.htm?item=2098§ion=1 4. Hitec Feather - do not use, do not buy off ebay at any price. http://www.servocity.com/html/feather_fm_rx.html5. Hitec Electron 6 - Works well - durability is questionable; a crash caused rattling inside and glitch problems. http://www.servocity.com/html/electron_fm_rx.html 6. Hitec HFS-05S - have not tried but many in EZ forum have reported very reliable, long range. http://www.servocity.com/html/hfs-05s_fm_rx.html |
| Thread Tools | |
| Discussion Sig Four Star 40 ARF Engine recommendations and Building Tips | Daverp | Beginner Training Area (Fuel) | 24 | Jul 12, 2009 02:38 PM |
| Discussion Finished building my easy star :) | lee2005 | Foamies (Kits) | 2 | Mar 02, 2007 05:10 PM |
| Simple 400 Building Tips? | 99esq | High Performance | 4 | Sep 10, 2001 07:07 PM |
| Wattage F-22 Building Tips / Pictures | rcfanatic | Foamies (Kits) | 9 | Sep 08, 2001 02:25 PM |
| IFO Mark3: Any last minute building tips ? | volt flyer | Parkflyers | 13 | Jun 21, 2001 03:33 PM |
