Old Jun 17, 2014, 04:54 PM
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
Help!
Pulse XT 40
I have been commissioned to repair a Pulse XT 40 that was rescued from the trash bin. Anyone got one of these the could pop the cowl off and give me some firewall measurements? I'd like to get the nose repaired before the cowl gets here....
Tucci is offline Find More Posts by Tucci
Old Jun 20, 2014, 06:08 PM
Tucci's Avatar
Joined Sep 2012
NO help?
Old Jun 20, 2014, 06:14 PM
Canada, MB, Gunton
Joined Jan 2014
I'll go pull the cowl off mine right away. I'm guessing you want height, width, thickness????
kwblake is online now Find More Posts by kwblake
Old Jun 20, 2014, 06:49 PM
Canada, MB, Gunton
Joined Jan 2014
Ok. Here is what I got. Width 90mm and then there is the 1/16 ply skin on that. Height is 93mm to top of radius, again 1/16 skin top and bottom. 1/4 inch thick. Now there is the two notches on the upper "corners". The width of the firewall, at these notches is 78mm, and they are approx. 10mm high at the tallest point. Hope this helps a bit.
If you need some more info, I will only be home for 1 more day........then off to work for another 3 weeks.
Old Jun 21, 2014, 06:11 AM
Tucci's Avatar
Joined Sep 2012
Very helpful! Thanks so much!
Discussion H9 Pulse xt 40 or AcroWot? Pedmondsonni Sport Planes 10 Apr 23, 2014 07:26 PM
Wanted pulse xt 40 wing lorhd2005 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 13, 2014 03:56 AM
For Sale Pulse xt 40 lorhd2005 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 16, 2014 08:28 AM
Build Log Pulse xt 40 build questions cneedforspeed1 Fuel Plane Talk 10 Dec 06, 2013 11:35 PM
Discussion Which plane pulse xt 60 or pulse xt 40??? rcmad1002 Fuel Plane Talk 67 Nov 06, 2013 06:25 AM
