Old Jun 25, 2013, 11:07 PM
Denver, CO
Joined Dec 2005
I don't know if its any harder on mode 1.
Don't let the others make you think your doing something fundamentally wrong by using expo. Some don't like it, some do.
Helicopters, and there setup varies greatly, might as well adjust it to fly how you like it.
If you search some of the top pilots setups you'll see that most use expo. And most use a
larger amount on the rudder. Also, they use different amounts on similar sized helicopters setup slightly different.
Typical numbers I see are 15 to 20% on cyclic, while several are above 35%.
Roto Rob is online now Find More Posts by Roto Rob
Old Jun 26, 2013, 12:00 PM
P.I.Engineer's Avatar
United States, CA, Redondo Beach
Joined Mar 2005
oh, mode 1, can't help you there.
for expo, i run 20% all around. I have no problem doing any trick.
P.I.Engineer is offline Find More Posts by P.I.Engineer
Old Jun 26, 2013, 12:29 PM
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Tell you what, at least turn it down from 30! And try this on the sim first. Take those side by side tic tocs at 30, then drop down to 10 or even 0, and watch what happens. Alot of this depends on too many variables. TX and gymbal sensitivity and wear. Servo speed. Even his genetics play a factor here. As does the fbl controller itself. Blades, and setup.
Luvmyhelis is online now Find More Posts by Luvmyhelis
Old Jun 26, 2013, 06:08 PM
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
LMH - I have dropped the exp to 0 on my sim i did notice the difference.
I belive there is so many factors involved here.. Servo speed, HS, Expo, Pitch and my skills. From everyones input its not just 1 factor.
Once I sort out my electronics and the weather permits I'll drop my expo to 15-20% on the cyclics and see what happens.
Also... my heli is NOT an FBL setup. I'm still ol'school
Cheers
evltoy
evltoy is offline Find More Posts by evltoy
Old Jun 26, 2013, 08:33 PM
Luvmyhelis's Avatar
Joined Oct 2010
Ahhh, flybar! Nothing like pure skill.
Discussion Swift: too-low tic-toc at the Circumgyration chopperdave Electric Heli Talk 30 Jul 02, 2006 12:52 PM
For Sale 1969 Odsmobile 442 tic toc tac and ralley steering wheel Greg Athey Non R/C Items (FS/W) 0 May 23, 2006 10:19 AM
Discussion so i was practicing the tic toc.... driftinsequence Mini Helis 3 Apr 02, 2006 08:02 PM
Tic Toc EddieNewYork 3D Fuel Heli Flying 21 Oct 06, 2004 03:45 PM
FS TIC TOC motor glider Seattle area only fly2mike Aircraft - Electric - Airplanes (FS/W) 0 Mar 16, 2004 11:53 AM
