Old Nov 06, 2014, 02:21 AM
wow so fly
United States, CA, Palo Alto
Joined Dec 2013
Question
Trex 250 DFC
I have a question regarding the swash movement on the 250 DFC Plus, I got this heli new RTF but have yet to fly out of paranoia. One of the thing's I've noticed is that when I tilt the heli to the left, the swash briefly responds by tilting to the right for perhaps a millisecond and then appears to level itself. The same behavior occurs vice versa. I'm not too sure if this is a characteristic of DFC/flybarless systems but I just wanted to make sure before I maiden her.
More generally speaking, what are the characteristics of a flybarless heli? as in when I tilt the heli to the right (no stick inputs), should the swashplate tilt to the left and hold left until the heli is level again to keep the heli stable?
Thanks guys!
mrpotatohead2234 is online now Find More Posts by mrpotatohead2234
Old Nov 06, 2014, 02:33 PM
United States, OR, Canby
Joined Aug 2011
The flybarless system will tip the swash to counter un-commanded movement. If you tip heli right swash should move left. How quickly it returns to level depends on how you are moving or not moving the heli. It sounds like yours is correct.
600Bob is online now Find More Posts by 600Bob
Old Nov 07, 2014, 12:43 AM
wow so fly
Joined Dec 2013
so when i tilt it and hold it still at an angle, it should level the swash parallel to the body?
Old Nov 07, 2014, 12:56 AM
Joined Aug 2011
Well off the top of my head I would say if you tip the heli the swash will move opposite and stay there until you return the heli to level. It's not something I really paid attention to but as a preflight you just make sure the swash moves in the correct direction when you move the sticks and when you tip it the swash corrects for the movement. If it does these two things don't over think it just fly it.
Old Nov 07, 2014, 10:37 AM
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
What you're describing is the behavior of FBL systems, like 600bob said. Any direction that you tilt the heli, it should counter in the opposite direction. The swash should remain level with the ground (more or less) when you tilt the heli.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: Thank you, veterans
Old Nov 07, 2014, 11:46 AM
wow so fly
Joined Dec 2013
What I'm observing is that when I tilt it with no stick inputs, the swash initially angles itself opposite of the direction of tilt but right afterward when I'm still holding the heli at an angle, the swash returns to parallel to the body. Should it still be countering this tilt?
Old Nov 07, 2014, 12:57 PM
Joined Aug 2011
It depends on how the programmers want it to respond, if that is what it is doing then it is probably normal for that design. The correction to tilt you describe is correct, I would go fly it.
Old Nov 08, 2014, 02:14 PM
Flying a recreational vehicle!
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
Originally Posted by mrpotatohead2234 View Post
I......when I tilt the heli to the left, the swash briefly responds by tilting to the right for perhaps a millisecond and then appears to level itself.
maybe it has very little stabilization(gain?) dialed in? my heli when i tilt it, the swash tilts the other way and slowly returns to center. maybe yours is set up for aggressive maneuvers..?
zyx-s and 3x1000 both return slowly back to center on mine.
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Nov 08, 2014, 02:20 PM
Joined Aug 2011
As a thought a real flybar would probably also return the blade pitch back to the "level position" after a few moments too. A stabilization controller like Fly Mentor would try to keep the swash level with the ground plane.
Old Nov 09, 2014, 12:28 AM
wow so fly
Joined Dec 2013
So how does a flybar system work in contrast to FBL? My flybar heli swashplate does nothing when I tilt the heli (as expected?) is the work done instead by the paddles?
I have the 3g MRS on the plus, wondering if it's anything with that.
Flying Pitcher, when you tilt your heli and observe that behaviour, are you holding the heli at that tilted angle or un-tilting the heli back parallel to the ground? Mine is re-leveling the swash
really fast, not sure if i should be worried about that. When I input stick movements though (on the ground) and center the sticks, it re-levels rather slowly compared to the behaviour mentioned previously(where I tilt the heli). Is this a standard setup?
Thanks guys!
Old Nov 09, 2014, 01:18 AM
Joined Aug 2011
In a flybar unit you control the swash which in turn controls the flybar, the flybar controls the blade pitch. In a flybarless unit you control the FBL unit, it controls the swash which is connected directly to the blades. The FBL does what the flybar does only electronically with more precision and user adjustability.
Old Nov 09, 2014, 04:15 PM
Joined Apr 2013
when i tilt my heli and hold it tilted that way, the swashplate countertilts and then slowly crawls back to centered position, even though i keep holding the heli sideways but it does take a few seconds. my FBL is set up to beginner mode too, so it's "softer ride"
Old Nov 11, 2014, 03:46 AM
wow so fly
Joined Dec 2013
awesome, looks like my heli behaves somewhat the way you guys describe so I guess I'll fly her soon, with training gear though. Thanks guys!
Old Nov 11, 2014, 08:10 AM
Joined Apr 2013
good luck, man. take it easy as she's a little girl, but with lots of energy
Old Nov 11, 2014, 12:20 PM
Tucson, Az
Joined Feb 2007
How much experience do you have flying c/p helis ? Not trying to be prying. Being real nervous keeps you on toes but could also make you do wrong thing at bad time. This is a nice heli and sounds like its ready to go. Is the flyer ? Like its been said take it slow. My friend has one and been a very good bird for him. good luck
dankar04 is online now Find More Posts by dankar04
Sold Trex 250 DFC Plus W/ Many extras LTHeli Aircraft - Electric - Helis (FS/W) 6 Oct 26, 2014 07:52 PM
For Sale TREX 250 DFC Pro lightweight w/ 3GX krea Aircraft - Electric - Helis (FS/W) 8 Oct 20, 2014 01:47 PM
Sold TRex 250 PRO DFC BNF $250 shipped flythk Aircraft - Electric - Helis (FS/W) 5 Oct 13, 2014 12:36 PM
Help! 3GX MRS Issues on Trex 250 Plus DFC? 1FlyingGuineaPig Micro Helis 0 Oct 13, 2014 06:50 AM
Sold Trex 250 Plus DFC Complete BTF Dcope17 Aircraft - Electric - Helis (FS/W) 3 Sep 26, 2014 09:26 AM
