Old Mar 02, 2014, 06:59 AM
Belgium, Walloon Region, Namur
Joined Feb 2014
ESC for Turnigy D2826-10 1400 kv motor
Hi,
HobbyKing product's page recommends a 40A for the Turnigy D2826-10 1400 kv motor while the max current is "only" 21A.
Even when checking with "Lipo-ESc-Motor-Prop" on-line calculator, I never reach 40A.
So here is my question : is a 40A ESC mandatory ? Wouldn't be a 30A ESC enough ? Taking in account that a 30A ESC is also far cheaper (ex. Plush 30A vs 40A) ?
Thanks in advance for your recommendations.
Ivan
kittyhawk1974 is online now Find More Posts by kittyhawk1974
Old Mar 02, 2014, 08:14 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A 30A ESC is more than adequate for a 21A load.
If you haven't already got one, put the money saved towards a wattmeter, just to make sure you don't exceed the safe amps.
eflightray is online now Find More Posts by eflightray
Old Mar 02, 2014, 11:47 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
At 50g that motor on 3s shouldn't be asked to draw more than about 14A/150W (3W/g)... even pushing it to 200W (= 4W/g) you'd still be drawing <20A.... a 30A ESC is plenty.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 03, 2014, 08:27 AM
Joined Feb 2014
Thank you very much for your precisions.
I plan to usee this motor/ESC combination in a Bixler 2 (with 4 or 6 servos) from HK.
Is there a "best" choice regarding the ESC ?
I think I need at least a 3A SBEC/UBEC ESC in order to power 4 or 6 servos.
Are Turnigy Plush ESC's a real advantage over other HobbyKing ESC's ?
Thanks in advance,
Ivan
Old Mar 03, 2014, 04:42 PM
Dr Kiwi's Avatar
Joined May 2003
Turnigy Plush do have a far better reputation than some other el cheapo HK offerings.
But to get even a 3A switching BEC you have to go up to an 80A Plush ESC (all the smaller ones [20A/40A/60A have linear 2A or 3A BECs)
You may want a stand alone external BEC (such as a Castle 10A) to ensure you have plenty of power for half a dozen servos.http://www.castlecreations.com/products/ccbec.html
Old Mar 03, 2014, 06:49 PM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Thanks in advance,
Ivan
Go with a 40 amp if you are concerned with needing a 3 amp switching bec.
The item linked below is a Hobby Wing Pentium/Turnigy Plush rebrand. I have been using them for years and they are rock solid.
http://www.hobbypartz.com/60p-dye-1004-40a-esc.html
Rich in ILM is offline Find More Posts by Rich in ILM
Old Mar 03, 2014, 06:59 PM
Dr Kiwi's Avatar
Joined May 2003
But, Rich, does that have a switch mode BEC?
Old Mar 03, 2014, 08:00 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
Check the table at the bottom of the 70 amp page:
http://www.hobbypartz.com/60p-dye-1018-70a-esc.html
Old Mar 03, 2014, 10:49 PM
Dr Kiwi's Avatar
Joined May 2003
Excellent! So they are actually superior to, and therefore not an exact rebrand of the Plush line which are linear all the way to 60A.
Old Mar 03, 2014, 11:47 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
I believe the 40 amp plush is mislabeled as linear. The ESC is rated from 2 to 6 cell lipo. And the BEC is rated at a full 3 amp continuous output. I have never seen either of those thing with a linear bec.
Old Mar 04, 2014, 06:59 AM
Joined Feb 2014
Thank you for you replies.
The reason I make reference to Hobbyking ESC is their affordable shipping charge (around 6 USD to Europe).
Indeed, shipping from Hobbypartz is simply too expensive (ex. ESC + programing card is 20 USD + 45 USD for shipping to Belgium !)
I think 3A (or 4A) should be OK for 6 micro servos (Bixler 2) : Rudder/Elevator - 2 ailerons + 2 flaps. Am I wrong ?
Here are the models I have checked (all are SBEC or UBEC) :
Hobby King 30A ESC 3A UBEC for 9.99 USD :
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
HobbyKing 40A ESC 4A UBEC for 16.69 USD :
http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html
HobbyKing 30A BlueSeries Brushless Speed Controller for 11.91 USD :
http://www.hobbyking.com/hobbyking/s...ontroller.html
TURNIGY Plush 40amp Speed Controller for 21.99 USD :
Your advices are of course welcome
Ivan
Old Mar 04, 2014, 08:11 AM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
Ivan
I would get the Plush from HK or here is another alternative if you use eBay:
http://www.ebay.com/itm/Hobbywing-Pe...item4ad160367a
They are one in the same. If you decide to add more planes you can standardize on this type of ESC and buy the inexpensive program card. This ESC is everywhere and well documented. i have been using them for 3 plus years and have been well pleased.
Old Mar 04, 2014, 09:55 AM
Dr Kiwi's Avatar
Joined May 2003
I don't understand the SBEC/UBEC terminology for these ESCs.. they have built-in BECs, most of them (?all) linear.
My understanding of "UBEC" or "SBEC" is a stand-alone BEC used in conjunction with an ESC (necessary with an OPTO, or with a built-in BEC's power lead disconnected) .. like the Castle 10A BEC I linked to.
Old Mar 04, 2014, 10:11 AM
Joined Feb 2014
It seems to me that :
SBEC = Switched BEC
UBEC = Ultimate (Universal ?) BEC (commercial name for a Switched BEC type)
Specs sheet from HK site states that HobbyKing UBEC are switched ones.
For the Turnigy Plush : up to 30A = Linear BEC, 40A and over = Switched BEC
Ivan
Old Mar 04, 2014, 10:14 AM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
Look at the labels. 2 through 6 cell lipo is a guarantee they are switching bec's.
Sold TURNIGY D2826/10 MOTORS with MULTISTAR 15A ESCs Bill Yonescu Aircraft - Electric - Multirotor (FS/W) 3 Feb 20, 2014 05:06 PM
Question D2826-10 users, which prop gives the best results for a 1 meter wingspan foamie? alex.g.94 Electric Motor Design and Construction 3 Dec 12, 2013 01:50 PM
Question Which battery (and ESC) would be best for a D2826-6 motor? alex.g.94 Power Systems 28 Nov 22, 2013 05:26 PM
Sold Turnigy D2826-10 1400kv Brushless Motor NIB $12 shipped Mikemynameis Aircraft - Electric - Power Systems (FS/W) 6 Nov 19, 2012 08:19 PM
Sold 4 10 gram brushless motors and 4 plush 10 amp turnigy esc's for sale flyer_dad Aircraft - Electric - Multirotor (FS/W) 5 Aug 13, 2011 09:37 AM
