Old Feb 26, 2013, 11:00 PM
Canada, ON, Brantford
Joined Mar 2011
Motor pulseing
I had the same problem recently with an E-Flite Park 480 1020kv motor. It would start screeching and completely stop as I approached full throttle. Called Horizon in Champagne and they told me to return it only to have the same problem with the new one that they sent me. I tried changing the timing from low to medium and the problem went away. I can swing a 12X6 prop at full throttle now. Maybe I will be able to hang my Funtana X on the prop now?? Maybe not!!! Later...Ken
KenS22 is offline Find More Posts by KenS22
Old Mar 01, 2013, 09:48 PM
Scott
Australia, SA, Two Wells
Joined Feb 2012
Thanks for that. I was pretty much resigned to the fact it was a timing issue. Eventually I may get a new esc that can have lower timing and try it. Ill stick with the stock setup for now though.
wigsw001 is offline Find More Posts by wigsw001
Old Aug 22, 2013, 12:46 AM
Joined Dec 2008
I have the same problem with a turnigy 3648 on a castle 125 amp . Actually I'm on the 3rd motor . It surges on and off and then finally revs out . Sofar no luck . I did change the timing to high , lowered the voltage cutoff and changed the settings to outrunner mode but haven't tried it yet .
pencon is offline Find More Posts by pencon
Discussion Hubsan x4- won't lift off even at full throttle? -james- Mini Multirotors 11 Aug 07, 2014 09:20 PM
Discussion Motor pulses at 3/4 throttle but not at full throttle Crist Rigotti Power Systems 0 Oct 03, 2010 08:53 PM
Discussion motor pulsating at full throttle...possibly bad contact on one of the phases??? mattijs321 Power Systems 8 Jul 25, 2009 06:39 AM
Question Motor Pulsating at Full Throttle RMEFlyer Power Systems 2 Aug 25, 2004 11:05 AM
