Old Sep 01, 2003, 03:00 AM
Newbee
Guest
n/a Posts
Aircraft forward/aft balance
Without going out and buying one of those balance devices is there a simple
inexpensive way of verify proper airplane balance? I was just going to flip
it over and place wing lead edge on raised surface to find balance point.
Any other suggestions? Thanks ahead of time...
Old Sep 01, 2003, 03:01 AM
Malcolm Messiter
Guest
n/a Posts
Re: Aircraft forward/aft balance
I always balance the 'plane using just my fingers too - your method is fine!
"Newbee" <wolf5150gang@hotmail.com> wrote in message
news:Iio4b.84383$xf.73174@lakeread04...
simple
flip
Fred McClellan
Guest
n/a Posts
On Sun, 31 Aug 2003 11:15:53 -0400, "Newbee"
Care to build your own CG machine ?
Surf to http://home.bellsouth.net/p/pwp-modelbof and check out
"Vanessa".
Cheers,
Fred McClellan
the dash plumber at mindspring dot com
SKYLANE42
Guest
n/a Posts
Use your fingers and find the spot.. you won`t be that far off. The cg on most
planes should be right about on the spar unless you have a special wing
configuration. The plane should nose down slightly at the cg.
Red Scholefield
Guest
n/a Posts
There are also instructions and plans (diagrams) for building one. I've
posted the .pdf file at www.rcbatteryclinic.com/Temp/balance.pdf
Red Scholefield AMA 951 District V
"Fred McClellan" <the-plumber@mindspring.com> wrote in message
news:v8c4lv8nkenifkmo435k9q5e68go0c34ql@4ax.com...
simple
flip
> "Vanessa".
> Cheers,
> Fred McClellan
A.T.
Guest
n/a Posts
"Vanessa" Jim Archer's sling and plumb bob method as shown on Fred's page is
excellent, especially for large models, but to calculate CG and MAC,
positions etc refer to =
Calculators, Conversion, C of G, MAC, Servo Torque calculation charts
(Flight trim see above) at http://homepages.ihug.co.nz/~atong/ if the
following do not appear as direct links on your screen =
Conversion & Calculation tables etc
CG & MAC - Graphic
CG - Canards - site down email Alan for a copy.
CG & MAC calculator = PJB's Seriously Aeronautical Stuff
CG Sling & Balance beam "Vanessa" Zip file - email Alan for a copy.
CG Sling
Convert - free download - convert units from one type to another ****
Design Calc - from Van's Place (site down - email Alan for a copy.)
Entisoft Units -- Measurement Conversion Calculator --
Performance Slide Rule Calculator - Servo torque, Horsepower, Stall Speed
etc.
R/C Aircraft Proving Grounds - CG, MAC, Servo & Basic Model Calculators
RC Calculators - C.Gadd. [Servo Torque, Wing Loading, Glow to Electric etc.]
regards
Alan T.
Alan's Hobby, Model & RC Web Links
simple
flip
Paul McIntosh
Guest
n/a Posts
Use your finger tips under the wing to find the balance point. Most sport
planes are designed to balance very hear the spar on built-up wings.
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
simple
flip
Pé Reivers
Guest
n/a Posts
Balance on your fingers. The nicest rubbery support around.
Starting balance point at 25% of mean chord. Then let flicht characteristics
guide you through the process of fine tuning to your specific wishes.
There are many good trimming articles on the network.
Rgds,
From Arcen, South-East in the Netherlands
preivers
mvvs-nl.com
http://mvvs-nl.com/
www.prme.nl
simple
flip
Old Sep 01, 2003, 03:02 AM
jeboba
Guest
n/a Posts
Put your fingertips next to the fuselage. NOT out at the wing tips!
"Paul McIntosh" <paul@mcintoshcentral.com> wrote in message
news:bitotg$gqp$1@hercules.btinternet.com...
> Paul McIntosh
> simple
> flip
point.
Forward/aft location of floats w/respect to plane cg cessnajfb Waterplanes 14 Sep 01, 2005 09:11 AM
