Old Apr 03, 2013, 04:44 AM
Joined Apr 2013
Wasp X3V Gyro?
Hi
I am new to helis. I have the above heli, new a week ago.
I had a couple of really good flights first off, then had a good crash nose first into the ground.
Replaced tail boom, push rods, main shaft, landing gear. Now the tail servo seems to act funny is a bit jittery or slow moving and it wont centre well specifically if you hold the control all the way for a bit. So after some forum hunting swapped channel 1 with 4 then the aileron would act the same. So is this telling me to replace the gyro.
Cheers
Phil
Phildo J is offline Find More Posts by Phildo J
Old Apr 05, 2013, 01:25 AM
Pontiac/Auburn Hills, Michigan USA
Joined Dec 2008
Originally Posted by Phildo J View Post
Hi
Cheers
Phil
First try replacing the tail servo. The Skyartec Tail Servo is a digital servo. Channel 4 on the receiver is really designed for a digital servo and not analog. Last time we tried a analog servo on channel 4 it over heated and burned out quickly after much jittering.
It is doubtful you have to replace the receiver/gyro unit-
do you have the X303v receiver 3axis gyro unit?
Hope this helps
Max
www.parkrcmodels.com
www.skyartec-usa.com
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Apr 05, 2013, 03:52 PM
Joined Apr 2013
Thankyou for your reply.
I will try replacing the tail servo.Yes I have the X303v. Hopefully I haven't damaged the anolog servo then.
Phil
Old Apr 07, 2013, 02:17 AM
Joined Dec 2008
Phil
Great! keep us updated
Max
Site Sponsor
Old Apr 19, 2013, 05:08 PM
Joined Apr 2013
Got a new servo but the same issue is still there i tried to upload a video for you but i can't here.
Old Apr 20, 2013, 07:18 AM
Joined Dec 2008
Video won't help much. Without it on our work bench it would be difficult to troubleshoot the issue.
Max
Site Sponsor
Old Apr 28, 2013, 07:30 AM
Joined Aug 2012
Phildo, This may be a dumb question but did you try flying it and if so does it fly normally?
You can't always reliably judge the servo/gyro's operating characteristics with the heli sitting stationary.
If it flies OK then you don't actually have a problem.
Pa flyer is offline Find More Posts by Pa flyer
Old Apr 29, 2013, 06:36 AM
Joined Dec 2008
Pa is correct; the X30v Receiver, is set in Head Holding mode and the tail servo doesn't necessarily have to center perfect on the ground and the tail servo may move a little slowly when stationary. Try to fly the helicopter in a low hover and see how it behaves
Max
Site Sponsor
Discussion wasp x3v waspyelsew Mini Helis 2 Mar 09, 2013 12:04 PM
Discussion wasp x3v waspyelsew Skyartec 6 Mar 08, 2013 08:18 AM
Sold Flybarless Skyartec Wasp X3V RTF *PRICE DROP* $90.00 SHIPPED!!! HyperHelis Aircraft - Electric - Helis (FS/W) 1 Feb 22, 2013 01:27 PM
Sold Flybarless Skyartec Wasp X3V PRICE DROP $90.00 Shipped!! HyperHelis Aircraft - Electric - Helis (FS/W) 0 Feb 21, 2013 03:04 PM
Sold Skyartec WASP X3V 3-axis Flybarless RTF w/ 2.4gHz LCD TX JHawk19 Aircraft - Electric - Helis (FS/W) 5 Feb 06, 2013 03:38 PM
